taillights unequal voltage
Old Jul 22, 2023 | 06:15 PM
carlmeson's Avatar
carlmeson
4wd Low
Got a 2014 f150. Left tail light only receives 5.7 volts while right tail light receives 11.26 volts. causing hyper blinking. Any suggestions????
Old Jul 24, 2023 | 08:56 PM
steve(ill)'s Avatar
steve(ill)
check ground on the bulb socket.
Old Jul 25, 2023 | 06:31 AM
projectSHO89's Avatar
projectSHO89
Are you measuring them using the same ground connection point with your meter?
Running/parking lamps or stop/turn lamps?
LED or incandescent bulbs?
Original or aftermarket lamp assemblies?
Old Jul 25, 2023 | 10:47 AM
carlmeson's Avatar
carlmeson
4wd Low
All original assemblies, . Incandescent bulbs, Run/Park, Stop /Turn all much dimmer than other side and hyper flashing.
Old Jul 25, 2023 | 11:01 AM
projectSHO89
You didn't answer this question.
Do check the grounds as suggested by steve(ill), especially if you did not use a good, common, and clean ground for making your reported voltage measurements.
Old Jul 25, 2023 | 10:48 PM
steve(ill)'s Avatar
steve(ill)
Clean on of the sockets on the outside and clip a jumper wire to it and to a GOOD GROUND... see what the lights do after that.
junkyardmonkey
Jul 7, 2011 09:47 AM
John Thomas II
20
Nov 7, 2005 09:22 AM
John Thomas II
Electrical Systems/Wiring
Nov 5, 2005 08:16 PM
mcne
Jun 12, 2005 08:35 AM
customline
May 17, 2002 01:11 AM
