Changed fuel filters
Old Aug 16, 2023 | 01:29 PM
  #31
Overkill2's Avatar
Overkill2
Originally Posted by WXboy
Yes I just signed papers on this truck this week, so I'm catching up on maintenance that has no records of being done. Have you ever found sediment/dirt in the bottom of your filter housing when you slide the cartridge filter out? Mine had a pretty good accumulation of sediment in the bottom. I cleaned it all best I could before reinstalling the new filter. But I wonder how that got in there?? Had to come in through the diesel filler neck, right?
Yes I have...
Originally Posted by FishOnOne
I'm overkill too when priming my filters.
Mine always has a little sediment in the filter housing. Pretty sure this sediment is coming from the storage tanks.
What Troy said.
Old Aug 17, 2023 | 04:13 PM
  #32
acdii's Avatar
acdii
I am still puzzled as to how debris can get outside of the water filter separator thing filter. There are two lines, one on each side that connect TO the filter Maybe I missed it, but is there a third line that fills the case and then forces fuel through the filter? This is for the 17+ filtration where the pump is in the tank.
Old Nov 7, 2023 | 06:34 PM
  #33
1dennis3's Avatar
1dennis3
I found that if you don't really crank down the bolts on the filter by the fuel tank that it won't start.
Old Nov 8, 2023 | 04:43 AM
  #34
Euroman's Avatar
Euroman
or if the water drain valve is not screwed up tight.
Old Nov 8, 2023 | 11:42 AM
  #35
WXboy's Avatar
WXboy
How often do you guys crack open the water drain and let it run? Seems that when I did it last time I lost about a half gallon of fuel at least. Not a big deal but hey $2 bucks is a coffee. Is once per month safe if I don't suspect that I got garbage fuel and everything else is otherwise OK?
Old Nov 8, 2023 | 12:02 PM
  #36
4wd6.7L's Avatar
4wd6.7L
I don't do it religiously, maybe once or twice between oil changes. When you are just taking a sample out to look for water you only need to drain maybe 8 oz. You do not need to drain it till it stops.
The only time I have drained until it stops is during a filter change. That should yield up to a half gallon.
Old Nov 8, 2023 | 12:22 PM
  #37
helifixer's Avatar
helifixer
I have drained mine 1 time since 2019
Old Nov 8, 2023 | 06:59 PM
  #38
djousma's Avatar
djousma
I've only drained when I needed to start a bonfire.....
Old Nov 9, 2023 | 02:25 AM
  #39
Overkill2's Avatar
Overkill2
Or when I changed my fuel filters...
Old Nov 9, 2023 | 11:57 AM
  #40
acdii's Avatar
acdii
This.
Or when I got questionable fuel from an unknown station, but I get it from Kwik Trip when home or TA or Loves when on the road.
aballiett
Aug 29, 2022 07:23 PM
FML F250
Jun 11, 2022 04:08 PM
tekservefl
Feb 8, 2020 07:05 PM
adamadam
Jun 27, 2015 06:45 PM
GITTA7
Jun 5, 2010 06:20 AM
