05 excursion 6.0 - When modifying/ bulletproofing is it better to find a brand that you like and buy exclusively from them or to switch between brands getting the best from each company? Here are some parts I am looking at.
-Turner with display
- Coolant filter
- Fuel filter
- Blue spring kit
- radiator
You can get the same radiator that Bulletproof Diesel sells from Performance Radiator for substantially cheaper. I got it for $400 to my door. Just call.
- Coolant filter -Dieselsite
- Fuel filter - Ford/Motorcraft
- Blue spring kit - Ford/Motorcraft
- radiator -Mishimoto or Performance Radiator is a good option.
(Responses above)
When it comes to parts (sensors especially) for your 6.0, Ford is the best option with a few exceptions:
Coolant- CAT ELC, Rotella ELC, Final Charge ELC
Oil- If you prefer standard 15w40, Motorcraft. If you prefer 15w40 synthetic as I do Triax 15w40 agri. Mobil 1 doesn't seem to stand up to the chewing these engines out them through anymore.
Injectors- Ford, Holders Diesel, Full Force Diesel
HPOP- Not sure if your '05 has an '04 engine but if it does Terminator Engineering, Dieselsite, and CNC Fab make superior pumps to the stock round HPOP. The V4 style HPOP rarely fails.
