Oil pressure indication
Old Jul 19, 2023 | 09:22 PM
joendoodle's Avatar
joendoodle
I always hated that FORD (for years) uses an "idiot gauge" for oil pressure (if the switch is made up, the needle points just above 1/2 way).
I (finally after 14 years) added an electric transducer and gauge to my 140k + mile 2009 F150, it read higher than I expected (70psi+ while driving) (50psi+ idling w/ hot oil)
I went with electric because in my youth I added a mechanical oil pressure gauge in my car.. After about a year the fitting on the back of the gauge let loose and sprayed hot oil on my leg and carpet. And I don't want oil spraying on my (not carpet) rubber floor covering in my truck
Doubting the indication I did a "calibration" check, hooked up my mechanical gauge (I guess I trust it).. turns out (w/cold oil) they both read 65 psi at idle and trend up over 70 PSI as I raise the RPM to the 2000RPM range.. I guess I can believe my indications now (except of course the idiot gauge that doesn't move).
Old Jul 19, 2023 | 09:34 PM
RLXXI's Avatar
RLXXI
You're not alone. lol
Old Jul 19, 2023 | 11:41 PM
Tom H So. Ca.'s Avatar
Tom H So. Ca.
Been there. At least it was in my '62 with metal floor with plastic covers. Electric oil gauge is the only way to go.
Tom
Old Jul 20, 2023 | 07:57 AM
Alexz265's Avatar
Alexz265
Where did you plumb it to? A T on the oil pressure switch? On my expedition I ran it to the pipe plug on the back it the passenger head figure this was as close as low point of the system as I could get. 60-70 psi cold start. 30-40 in gear at 55 mph hot. 15-25 psi hot idle in gear with AC on. You numbers seem to match mine.
Old Jul 20, 2023 | 08:34 AM
joendoodle's Avatar
joendoodle
I bought a "pancake" like gizmo, it installs between the oil filter and the oil filter "mount" it has multiple ports, I used the 1 that positions the transducer "out of harms way
On "Plane Jane" (my XL) with the column shift, the shift lever partially blocks the view of the gauge in Drive.
I like your gauge, it looks like a nice 270 degree sweep..
Old Jul 20, 2023 | 11:26 AM
Alexz265's Avatar
Alexz265
I too bought a sun pro mechanical and decided I didn't trust the tubing in cab. Got it cheap on eBay. Heard mixed on glowshift but price was right. There was one day the stepper motor over ranged. But turned back off and on and no issues weeks later. I went with because the green LED setting and white face sorta matched the cluster. Was super bright on way to work so I had the tint shop darken it when I had it in for windows. I read about pressure swings with that pancake adapter. Any issues?
Old Jul 20, 2023 | 12:30 PM
joendoodle's Avatar
joendoodle
That "glowshift" gauge looks excellent...
I'll keep an eye out, post if you have any issues.. I may have to upgrade to a gauge that looks THAT COOL!!
I have had no (indicated) pressure swings using the "pancake" adapter.
Old Jul 20, 2023 | 12:48 PM
Alexz265's Avatar
Alexz265
Thanks I would recommended it. Very happy. I only needed a few brass fittings to get it mated to the back of the head. Pancake sure would have been easier. Have you done oil changes since install?
here's a couple links to my YouTube channel for videos of it.
https://youtu.be/91qPPiPBXc8
https://youtube.com/shorts/aeTeSc_lTpk?feature=share
Old Jul 21, 2023 | 10:02 PM
joendoodle's Avatar
joendoodle
Originally Posted by Alexz265
................................I read about pressure swings with that pancake adapter. Any issues?
JINX
I drove "Plain Jane" on a 450 mile road trip today, when I let off the throttle the needle bounced a little as it went down to 50 psi from 75 (+ or -).. I don't know what would cause this (too close to the oil pump?)
Old Jul 21, 2023 | 10:33 PM
Alexz265's Avatar
Alexz265
Never could read for comprehension. With a sandwich adapter, you're reading pressure between the pump and filter. The pump can slow down or speed up with the engine quickly and there isn't much of a buffer since you're so close. If you're running a Motorcraft filter, it has an internal bypass valve with I had thought opened at 15 psi differential pressure.
with my sending unit in the last leg of the system, the pressure changes are smoother. Or that's my best understanding of it. Could be wrong. There's nothing wrong with your setup. It clearly works.
Old Jul 22, 2023 | 05:36 PM
joendoodle's Avatar
joendoodle
Thanx, coincidently I am currently using a Motorcraft filter. I don't use them exclusively BUT the seem to be a good quality for the relatively low price point, So I have several on hand.
Old Jul 22, 2023 | 05:48 PM
RLXXI's Avatar
RLXXI
As a professional engine builder my recommendation for installing an oil pressure transducer is directly into the main oil gallery as far away from the oil pump as possible, which would be a cylinder head. That way you're reading the least possible pressure available in the engine.
With that said, todays electronic sensors are very much capable of indicating a loss of oil pressure in operation summarily shutting the engine off before damage occurs making any aftermarket gauges installed useless except for the fact they bring back memories of hot rodding days of yore and look cool as hell.
Rentaro
16
Jul 23, 2013 08:27 PM
LIGOOMBA
34
Jun 4, 2009 03:34 PM
dumpsterdan
3.8 & 4.2L V6
May 5, 2004 02:44 PM
yes1922
Oil & Lubrication
Aug 27, 2003 11:42 AM
tomk89xlt
1978 - 1996 Big Bronco
Mar 14, 2001 05:50 PM
