Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Look up VIN
Old Jul 18, 2023 | 02:11 PM
terribleterry's Avatar
terribleterry
4th Gear
Look up VIN
Hello I'm in the process of purchasing this vehicle. And would like to find out if the right kind & size engine & transmission are what came in it. But owner says it is a C600 & a 1978 model. But would also like to find out what part of the country it came from. D70GVAK1243
Thanks for your help
TerribleTerry
Old Jul 18, 2023 | 02:16 PM
85e150's Avatar
85e150
Welcome to FTE!
Love to help you but you have not posted the VIN or a picture of the warranty plate.....
VIN will have the engine but the trans and axle codes are on the plate, not in the VIN.
Old Jul 18, 2023 | 03:14 PM
terribleterry
4th Gear
Forgot vin
LOL..Damn that would be nice!
D70GVAK1243
Old Jul 18, 2023 | 03:33 PM
terribleterry
4th Gear
Forgot vin
D70GVAK1243
Old Jul 18, 2023 | 06:59 PM
85e150's Avatar
85e150
D70 = C700 Diesel (Possibly badged C7000)
G = Cummins V903 eight cylinder diesel engine, 903 CID
V = Kentucky Truck Plant
AK1243 = 1978 numerical series, October 1977 production
All your other info would be on the warranty plate on the driver door, if it's still there and if it's original.
Old Jul 21, 2023 | 10:28 AM
Destroked 450's Avatar
Destroked 450
Something is off with the vin decode
A 903 Cummins will not fit in a C cab truck
That engine was only available in the W, CL and some L series due to its large size
The Cummins 555 was available in the C model but it’s certainly no engine to brag about, actually it’s one to stay away from
It has about the same power and dependability as the 8.2 Detroit, for every one good one there’s a dozen bad ones
3208 Cat was the best diesel they put in a C cab chassis
Old Jul 21, 2023 | 06:16 PM
85e150's Avatar
85e150
The 6V-92 also comes up under that code for that year.
Is that a possible engine? The 555 doesn't show for that model year.
Old Jul 21, 2023 | 06:23 PM
terribleterry
4th Gear
Did they put a 903 Cummins in the C-700. That engine is awfully huge. I know they put the V-8 Cat in it. These numbers are on the door jam. Can anybody tell me what they mean. The guy Im trying to buy this truck off of took about 4 days to get the VIN number for me. Then he sent a picture of it to me and it looks like a brand new title. That VIN number is on the plate on the door jam. Is that where they put them. He says it also has a 460 gas engine in it.
VIN: D70GVAK1243
D70QVAK1243
206 M3 D703 4A8 J2
24000 71
Old Jul 21, 2023 | 10:21 PM
Destroked 450
6V-92 is also to large, it would have been in one of the models I mentioned above
Not sure what years the small V8 Cummins was used but I did see one in a 70’s C model fire truck
The small V8 Cat is the only other diesel I know of that will fit in that chassis
1150, 1160 are earlier versions of the 3208
Old Jul 21, 2023 | 10:25 PM
Destroked 450
VIN: D70GVAK1243
D70QVAK1243
206 M3 D703 4A8 J2
24000 71
If it really is a 460 I’d be leery of it as that would be something someone has swapped in
If it is a gas chassis it should have a 429 truck engine
Old Jul 22, 2023 | 12:12 AM
85e150's Avatar
85e150
'78 would be an FT wouldn't it.
OP should find the VIN on the frame as the one he's been given might not be for that truck.
Old Jul 22, 2023 | 01:12 AM
Destroked 450
Could be, half the time I can’t remember if it’s 78 or 79 when the switched
Old Jul 22, 2023 | 10:48 AM
85e150's Avatar
85e150
Post 8 says engine code Q. That is a Cat 3208. (Also another Cat 3406 but it's probably the 3208)
If it has a 460 in it then I'd be very wary of how it was converted.
Beard
Large Truck
Apr 27, 2016 04:38 PM
ocastari
Oct 5, 2012 10:55 PM
Thomas Kessenich
Jan 10, 2012 10:09 PM
bluefever
Aug 13, 2011 02:19 AM
markgb98
May 29, 2008 04:18 AM
