brake drum removal
I'm trying to pull the rear drums off and cannot get them to budge (the front two drums slid right off). They spin freely (well, sorta, in a non-binding, older sorta way, like the way I walk in the morning).
Do I
a) beat them with a hammer until they move
b) heat them with a propane torch then beat them until they move
c) order a really big three jawed puller from somewhere (the 8" loaner from Autozone isn't big enough).
d) attach a slide hammer to the lugnut bolts and whack at it until they move (Autozone loans that too)
e) something else???
What's the trick here? Help!
Bob
If your drums are rusted to the hubs try squirting some good penetrating oil in around the hub and wheel studs. WD40 does not work very well for this sort of thing. After a good soak try using a little "persuasion" to get the drum off.
If that still does not work, grind off the heads for the posts that hold the hold down springs for the shoes. This will give you enough give (while wiggling it around) to slip a screw driver into the drum and pry the shoes away from the drum. If you try to brute force the drum off at this point, you will wreck the brake cyl. or cause springs to go flying.
1. Loosen the lugs slightly, drive the truck about 10 feet forward and hit the brakes. Then do it in reverse. This should break the drum loose.
2. Take 2 crowbars and wedge between the drum and backing plate 180* apart. While holding pressure on the crowbars, have an assistant rap the axle center sharply with a heavy hammer. Hit it with several raps, so that vibrations are transmitted to the hub and drum.
Good luck.
Haven't two crowbars but I've got some 'tar arns' that will do.
Thanks!
Bob
1. backed off the adjusters all the way
2. Put 3&1 oil on the hub for 4 days (coated it every night after work)
3. Using tire irons, I wedged one in on each side of the drum between the drum and the backing plate so there was a lot of force on the drum.
4. Using a BFH and a drift, it whacked the drum near the backing plate (force applied towards the outside) a few times and it popped right off.
Note that even after backing off the adjusters, and when I was wedging in the tire irons, I could hear scraping, indicating the shoes were in a deep groove. When the drums finally came off, this was confirmed. I guess I had to force the drum over the shoes.
Thanks for all the help!!!
Bob
in my truck i just put it in granny and mash the brake as hard as i can and it works great
JUST BE CAREFUL when doing this
