Rear block size??
Old Jul 18, 2023 | 08:17 AM
Jk22's Avatar
Jk22
Rear block size??
Does anyone know the size of the rear block in a 2022 f250 swr??? Is it 3.25?? Or 3??
Thanks
Old Jul 18, 2023 | 08:34 AM
ToMang07's Avatar
ToMang07
It's 2".
dsjhsjt
Old Feb 15, 2024 | 01:28 PM
E16herbert's Avatar
E16herbert
1st Gear
Hope this helps someone
I have a 2022 crew cab short bed. I put the Bilstein 2 1/2” springs up front which made me an inch higher. I got a set of 17-19 rear blocks from a buddy at Ford and new u-bolts from the parts department and swapped them this morning. Level now on 35’s with 44 1/2” from the ground to the center of the fender well.
The swap took about 25 minutes and is ridiculously easy. For those that want to reverse level, the 20-22 F250 without plow package have 2” non tapered blocks. The 17-19 will absolutely fit 20-22. They are tapered so they are side specific.
the longer U- bolt part number needed for the 3” (17-19) blocks is BC3Z-5705-F
If anyone is interested in my 2” blocks and U bolts send me an email and we’ll work it out.
Old Feb 16, 2024 | 07:21 AM
RainDesert's Avatar
RainDesert
Thanks for sharing and the info, looks great. I am probably doing this to my 2022 at some point.
Old Feb 16, 2024 | 09:13 AM
speakerfritz's Avatar
speakerfritz
remember that srw have smaller pin holes and smaller pins on the blocks than drw's.
Old Feb 18, 2024 | 04:37 AM
Garbageman 134's Avatar
Garbageman 134
I have a 1.5" shim kit for the front springs but cannot find the Ford p/n for 3.5" Ford rear blocks that will fit my 22 f250 cclb srw.
Old Feb 18, 2024 | 06:08 AM
speakerfritz
If you are looking for tremor size blocks…discussion with part numbers here
https://www.fordtremor.com/threads/r...-blocks.12722/
austinb1017
Oct 29, 2021 10:39 AM
Philcsag1
Oct 23, 2021 04:19 PM
pkenn7
Jun 29, 2018 06:43 AM
dh1200
Aug 17, 2016 06:16 PM
