A/C over pressure
Old Jul 18, 2023 | 12:51 AM
VeryEye's Avatar
VeryEye
1st Gear
A/C over pressure
I have a 2006 f350 6.0 . My a/c is over pressuring. I have replaced the condenser, compressor, acccumulater and the orifice tube. Had a shop perform a vacuum and pressure test while adding refrigerant. They said it high side over pressured. Seeing as everything was replaced what could the problem be?
Old Jul 18, 2023 | 06:14 AM
projectSHO89's Avatar
projectSHO89
Define "over pressure". Actual numbers and conditions.
Old Jul 18, 2023 | 05:00 PM
tjc transport's Avatar
tjc transport
i ain't rite
"over pressuring" usually means there is a blockage in the system somewhere.
i had an 06 F150 come in with the same issue. 1/2 pound refrigerant had 350 psi high side gauge.
the accumulator had a clear plastic cap stuck into the side port under the black cap.
the guy did not see it when putting the system together.
took me close to 3 hours to find it. once that cap was out it charged properly.
Old Jul 18, 2023 | 07:38 PM
projectSHO89
In your case, you would have also had a severe "under-pressure" condition on the low side.
Until the OP clarifies, not much use in speculating.
FBODY4U
1997 - 2003 F150
Sep 3, 2021 10:07 AM
F1 coyote
Garage & Workshop
Jul 8, 2021 05:50 PM
clevelandtundra
May 7, 2013 07:49 AM
provosc
Mar 12, 2010 09:03 AM
Scott C
May 7, 2003 08:45 PM
