CPS Harness
Old Jul 16, 2023 | 05:56 PM
patrickg450's Avatar
patrickg450
CPS Harness
2003 7.3L with 195,000 miles
This is my pull vehicle so you can see the low mileage and she is a garage queen. I have not done a CPS in.....well I cant remember the last time I did one. About 90 or so days ago, I went to go get fuel before hooking the RV up. In the gas station parking lot it would not start. Did the CPS and I was going in no time, easy fix. Bought a new one from FORD, my buddy is a mech there so employee pricing is pretty cool. Well this Friday I was headed out to the lake and she died on the road. Pulled out the spare, had to wait a good 30 mins for it cool down but we go it going again. Today on the way home from the lake it died......with no parts and no one close by I put the old one back in. I did check the pins and connector, it all seemed fine. Got going on the "old' one I pulled out on Friday........about 120 miles later it dies again. This time I left it in, but I had spayed a bottle of water down on it (or at least tried) and she started back up after 10 mins or so......
The only real thing I can say is when it failed: I had a loss of power, RPMs were still holding but no "go" for about 20 seconds or so then the tech dies and the dah lights come on. Previously when I loss one, it dies immediately and the tech goes down immediately as well. This made it seem like it took a minute for truck to realize she had an issue.......weird.
So I thinking it needs a new wiring harness, I found some old threads and it seems logical at this point. Any advise on this is appreciated, I am home and she is back in the garage with the hood up.
Do I need to pull the AC COMP so I can pull the old one back? Reroute it? Make it a bit longer so I can zip tie it out of the way? How far back did you folks go to splice in the new one? They are all the same color.......so one of one swap?
Seems a bit tight in there (TWSS)
PG
Old Jul 16, 2023 | 08:23 PM
John in OkieLand's Avatar
John in OkieLand
get a new CPS pigtail
https://www.riffraffdiesel.com/cps-h...pigtail-94-03/
Old Jul 16, 2023 | 08:25 PM
patrickg450
Yea, I did say harness. I should have said pigtail. Any insight on the install?
Old Jul 16, 2023 | 09:01 PM
uglypitbull's Avatar
uglypitbull
last time that happened to my buddy, it ended up being his IPR. I swapped out his CPS and it fired right up....then died again a half mile down the road. I towed him home and that's when we started testing.
Have you checked for soft codes yet?
Old Jul 17, 2023 | 02:54 AM
udsuth78's Avatar
udsuth78
X2 on IPR related. Check the tin nut and wiring if all the checks out test the resistance of the coil.
Old Jul 17, 2023 | 06:38 AM
RacinJasonWV's Avatar
RacinJasonWV
I agree (x3) on the IPR thoughts. Once it cools down a bit it may work correctly again. Folks typically recommend pouring some cold water over it or spraying with some “air duster” to cool it down when it’s acting up as a verification of it being the issue.
Old Jul 18, 2023 | 12:57 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Sounds heat related so x4 on failing IPR coil.
Next time it happens try to cool it as suggested above.
Old Jul 19, 2023 | 03:42 PM
patrickg450
Got an IPR and CPS pigtail coming, might not need the pigtail but I had to order the IPC on line so I added the cheap part......
Let's see how it goes, will try to install tomorrow night
Old Jul 21, 2023 | 01:45 AM
aawlberninf350
It's a Van Gogh
Time to pour out a dram or smudge some sage, maximize your luck.
ckal704
Sep 6, 2017 09:18 AM
barkmulcher
23
Sep 2, 2011 01:14 PM
PSNut
26
Jul 17, 2008 07:30 PM
OTTOMATIC
Nov 25, 2007 09:51 AM
Mindstream
34
Jan 26, 2007 07:32 PM
