2000 7.3 troubleshooting, rough running and codes
My hypothesis is that I either have a high pressure oil leak like injector seals bypassing, an IPR valve problem, or a high pressure pump that is worn out. Being as everything but injector seals is a significantly expensive endeavor (and I would like to retain my marriage - she hates the parts cannon BTW), I figured I take the phone a friend option and see what the zen master 7.3 guys out here had to say. The other issue I have is that I don't know Forescan very well and I don't know how to check DIDM codes. Once the engine warms up and the service light starts turning on and off, I get a code in the PCM for DIDM codes present but have no idea how to get to them.
Thanks in advance for your advice...
When you did the harness, gaskets, sensors, and control items did you get them from the Ford or International counter guy or did you online them? Any part ordered online is 99.999999% likely to be fake, even with the Ford or International name on it. There are maybe five places you can order online and get real OEM. Cramazon, Fleabay, and the corner store are not your friends for this truck. You Must have OEM or the engine will never be happy.
As for the injectors there are maybe two or three places to get rebuilt that will do you right. Where did you get yours?
Contribution tests only ever tell part of the story... #8 will almost always fail or be at least 3% or more than the rest, #3 sometimes the same story.
What are you using to pull codes and run tests?
Have you checked every single connector on the engine harness physically for proper attachment and condition including several inches into the loom?
Have you verified 100% clean, tight, no discoloration, no corrosion or history of corrosion on all battery feeds to include... Posts, grounds (battery, block, frame, fender), alternator connections, starter solenoid, and even the starter?
Are the batteries holding 12.6 volts or better overnight when checked with a proper volt meter?
What codes do you have currently?
Do you have a method to monitor fuel pressure?
Pull your fuel filter and look at the bowl and filter, do not drain it first. What do they look like?
Did you put any type of additives in the fuel or oil? Fuel additives are ok, oil additives cause issues.
More to come after answers.
I have the extended license for Forescan so that is what I am using for my testing. I was, 10 years ago, a Diamond Certified Navistar tech and was familiar with their software which was WAY more detailed in the data and had more tests available so I feel a little out of my realm software wise. Full disclosure, I was a drivetrain specialist however, so my experience with the 7.3 was limited. Being as I was a factory tech, I bought Ford factory harnesses and valve cover gaskets. The injector is from O'Reilly's - I have purchased a few of them over the years from them and have not had an issue that I can attribute to a rebuilt injector failure. The ICP sensor is new from Dorman. When I did the LOF, I cleaned the battery terminals and inspected cables. The batteries are brand new. and they stay up over night. I have checked chassis and engine ground connections. I have not checked power connections to the starter since those are not active once the engine is running. There are no fuel additives in the fuel and it is low sulfur. There was no junk or water in the bottom of the fuel filter housing when I pulled old filter, prior to any draining of the bowl. I did use terminal cleaner on the harness connectors when I swapped the valve cover gaskets, as well as the main engine harness plug since it had to be disconnected to pull the drivers side valve cover. A basic visual inspection of the engine harness didn't give me any red flags. I have not hooked up a fuel pressure gauge.... I believe it is sitting in a tool box about 300 miles away. Will grab another one this next week and I need to rescan for codes. The water line between my well and house decided it was at life expectancy yesterday so this weekend is going to be something other than a truck repair weekend.
The ICP being the corner store item would be on the change list also.
Check the CPS also. Pull the wrapping off several inches up and verity wire and connector integrity.
Check EBP, MAP, and BARO to see if there is on odd man out on a cold non running engine. Every one should be near 14.7 psi on a standard day at sea level, your location may vary a bit.
EBP tube and sensor is a common issue with rough running engines. Sometimes cracked tube, clogged at the manifold fitting, maybe the tube itself is clogged, may be a caked up diaphragm. Of the three tubes I have changed on three different trucks over the last few year none were serviceable any longer, after the second one the third I just had my buddy order the sensor and tube to replace.
