Styleside bed panel mounting kits
Old Jul 13, 2023 | 11:59 AM
FuzzyBeanBag's Avatar
FuzzyBeanBag
Hi all,
Gearing towards completely rebuilding my bed which likely means stripped/snapped OEM bolts and nuts holding the current panels. Wondering if anyone has a part list or can point me where I can get a full replacement for all fasteners related to the styleside beds?
Also - my existing 75's driver bedside has a single round hole for the gas filler. Unfortunately the panel is rusted through so I have a replacement which has a single square filler hole. Will the existing filler and vent hose fit?
Thanks!
Old Jul 13, 2023 | 03:50 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Old Jul 13, 2023 | 04:05 PM
monkey-1's Avatar
monkey-1
I just ordered a Master kit from AMK and am totally impressed with the packaging and individually labelled bags.
Old Jul 13, 2023 | 04:57 PM
FuzzyBeanBag
So I am a bit confused about the AMK master kit:
https://www.amkproducts.com/master-k...s&element=Body
It doesnt look like there are bolts specific for the bed, aside from the bed floor...? Or am I missing something? I see fender bolts but nothing specifically mentioned for bedsides.
The Body Bolt Kits though seem to have everything, but it's not explicitly spelled out what subkits they include...:
https://www.bodyboltkit.com/1973-197...body-bolt-kit/
Any ideas? Suppose I can reach out to them too
Old Jul 14, 2023 | 08:45 AM
mikeo0o0o0's Avatar
mikeo0o0o0
The styleside bed is pretty much all welded together. Other than the hardware for attaching the tailgate, bolting the bed to the frame, screws for the light lenses and fuel filler neck, and the bolts for the small fender supports it's all welded.
Old Jul 14, 2023 | 02:25 PM
FuzzyBeanBag
Originally Posted by mikeo0o0o0
The styleside bed is pretty much all welded together. Other than the hardware for the attaching the tailgate, bolting the bed to the frame, screws for the light lenses and fuel filler neck, and the bolts for the small fender supports it's all welded.
Ah that makes sense. So really minus the tailgate, the bed is mounted to the chasis with 8 bolts and nothing more?
What is the "small fender" you're referring to?
Old Jul 14, 2023 | 02:34 PM
hickory1991's Avatar
hickory1991
Mike meant the brackets that support the rear back portion of the bedside panel.
Old Jul 14, 2023 | 03:05 PM
flowney's Avatar
flowney
Don't forget the wiring before lifting the bed away from the frame.
Old Jul 14, 2023 | 07:56 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Yup, the small fender support brackets. They have one bolt in each end.
cybane
Aug 19, 2022 02:49 PM
66with352
May 17, 2019 06:42 PM
Smitty49
Jul 28, 2014 05:13 PM
bucks77ford
Paint & Bodywork
Jun 23, 2006 06:30 PM
