1978 - 1996 Big Bronco
Help replacing turn Signal Switch
Old Nov 19, 2003 | 10:33 AM
mareswj's Avatar
mareswj
Question Help replacing turn Signal Switch
Where do I unplug the switch?? The manual says to remove plug before removal and reverse to install. So I'm supposed to remove the plug from new switch then reinstall it after i install switch????
Any suggestions would be helpful.
I searched the threads and didn't find anything on the connector.
Thanks
Old Nov 19, 2003 | 10:57 AM
screwy's Avatar
screwy
what year?
On my 93 I removed the switch, then unpluged it.
Old Nov 19, 2003 | 01:00 PM
mareswj's Avatar
mareswj
sorry, 89 with Tilt wheel
Old Nov 20, 2003 | 03:35 AM
fordman_in_nv's Avatar
fordman_in_nv
I have an 88 with a tilt and I had to replace mine. Inorder to get the switch out you have to take the wires out of the plug so they can pass through the colum. I just cut the wires because I'm impaciant, and because I had a new one. Then make a diagram of the new one especialy because the wire colors probibly are'nt the same or on mine at least. The new plug had a little plastic clip that held the wires in, remove it, fish the wires down the colum then put them back in the plug. After that hope you made a good diagram. Hope this helps
Old Nov 20, 2003 | 07:10 AM
mareswj's Avatar
mareswj
thanks, I was afraid thats what i had to do.
amthatiam
Jun 2, 2012 12:42 PM
pbeaudet
Nov 4, 2011 06:46 PM
Wasilla
1983 - 2012 Ranger & B-Series
Nov 6, 2004 12:26 PM
mep123
Electrical Systems/Wiring
Oct 23, 2003 07:31 PM
