quick cooling question
Old Jul 10, 2023 | 06:43 PM
KAGAN21's Avatar
KAGAN21
hi all!
just bought a 4 row aluminum radiator and was wondering would i also need a high flow thermostat and high flow water pump to compensate for the larger radiator? or would a stock thermostat and water pump just be fine.
truck is a 96 f250 crew cab short bed 7.5L 4x4 automatic.
Old Jul 10, 2023 | 07:15 PM
My4Fordtrucks's Avatar
My4Fordtrucks
The stock 195° thermostat and water pump are fine as was the OEM size radiator. If the system is operating correctly they are more than enough to keep the engine cool.
Old Jul 10, 2023 | 10:20 PM
KAGAN21's Avatar
KAGAN21
still didn't answer the question.
Old Jul 10, 2023 | 10:36 PM
samuel4wolfpack's Avatar
samuel4wolfpack
The original one-row radiator on my 1991 F250 5.0L was leaking pretty badly a couple months after I bought the truck in spring of 2022. I was surprised at times the engine wasn't overheating amidst the leaks. I ordered a new FB222 two-row radiator and installed it with new hoses, and I replaced both my temperature sensors at the same time. I did not change my water pump or thermostat, since there didn't appear to be any leaks in either spot.
Old Jul 10, 2023 | 10:45 PM
KAGAN21's Avatar
KAGAN21
ok, nice that it held that long but still didn't answer my question.
Old Jul 10, 2023 | 11:18 PM
My4Fordtrucks
We both answered your question. Just because you installed a larger capacity radiator does not mean you need to increase how much faster the water circulates through the engine.
Old Jul 10, 2023 | 11:19 PM
samuel4wolfpack
I expanded my cooling capacity with the two-row radiator, just like you are expanding your cooling capacity with the four-row radiator. I didn't change anything, and I would imagine you may not need to. Now with my two-row radiator, I did have to change my original fan shroud to one from a 92-96 F-Series truck.
Old Jul 11, 2023 | 08:22 AM
manicmechanic007's Avatar
manicmechanic007
You will be fine with the stock parts working with the gigantor 909 radiator
I did the same on MY 150 van and love the running cooler
My big honkin radiator is working fine for me with a factory Ford 195 stat and the original H2O pump
Old Jul 11, 2023 | 09:16 AM
MountainManRobb's Avatar
MountainManRobb
You have to be careful with "high flow" components in your cooling system. If you get the flow going to fast, the water is unable to absorb the heat from the engine and it completely defeats the purpose of the cooling system. If anything, with the "gigantor 909" radiator, you almost want to slow flow to allow maximum heat exchange.
Old Jul 11, 2023 | 11:12 AM
Prototypemech's Avatar
Prototypemech
Don't underestimate the importance of a good fitting fan shroud. The fan shroud needs to touch the radiator around the entire parameter. Spend an hour with weatherstripping or split-rubber-hose to minimize the gaps in the shroud. Your temps will go down and your mpg will go up with a tight fitting shroud.
Virginiamv78
17
Feb 16, 2016 01:52 AM
linusr
Sep 14, 2013 09:42 AM
Josh Aarons
Jun 2, 2013 11:27 PM
plgebbia
Nov 13, 2010 05:32 PM
restoringmy46
Jun 15, 2008 02:03 AM
