Steering Box Question
Old Jul 8, 2023 | 02:11 PM
Rpirrott's Avatar
Rpirrott
Trailering
My 55 steering box has a zerk fitting on top. However when I loosened the adjustment screw on the side. 90Wt gear oil came out.
What is supposed to be in there? If I read the factory manual correctly just grease.
Old Jul 8, 2023 | 02:34 PM
ajsunnyB's Avatar
ajsunnyB
I am under the impression that fitting you talking about lubes the top insert It’s not a bearing, but a insert on the top where the steering shaft goes. The steering box has a six point plug I just serviced mine. With 140 gear oil same stuff I use in my Harley 78 FLH transmission mixed with Rizlone. I have a small amount of gear play in my steering box. That’s why I went to the higher grade of oil. Hey I am not up to speed on this subject. But I jacked up my front end and that’s how I found the play in my steering. Also I’ve got a few other issues with my stock suspension. A later check book eater! AJ
hotrodjohn71
Aug 27, 2023 11:59 AM
76f100ss351c
Oct 22, 2020 03:12 PM
amthatiam
Sep 29, 2018 04:01 PM
randy6971
Mar 8, 2003 09:13 PM
