This was self-induced, pretty mad at myself while running a wire I accidentally cut the small BU/GN and small YE-RD, and nicked the GN-OG. The code Im getting is
U0102:00-0A Lost communication with TCCM
aka the display, issue checks 4x4. Based on the wire schematics the BU/GN is a communications network wire Not sure about the YE-RD. I fixed the cut wires but that didn't help so I think the Nick in the GN-OG is the issue because that is the Module communication network (per the wire diagram). Researching more before I do anything to that wire
On forscan the log says it can communicate with TCCM but the error is cant read the DTC, Maybe I fried the module
So I fixed it, went through everything again found fuse 32 (F11) to be bad, my old eyes thought it was good the first go around, a Weird type fuse had to go to Ford to get one.
