CCV filter replacement help
Old Jun 29, 2023 | 07:24 PM
Canadian1's Avatar
Canadian1
2nd Gear
Hello,
I have 2011 F250 power stoke.
Do I need to remove fuel filter to replace CCV filter?
Old Jun 29, 2023 | 07:33 PM
speakerfritz's Avatar
speakerfritz
https://f01.justanswer.com/dcraig100...afbde_eee1.pdf
Old Jun 30, 2023 | 07:06 AM
senix's Avatar
senix
why are you doing this, There is no filter inside to replace.
Old Jun 30, 2023 | 07:53 AM
Canadian1's Avatar
Canadian1
2nd Gear
i thought the 1st generation had the serviceable ccv. I think mine is clogged as I'm getting smoke from the exhaust at idle. Also i removed the oil cap and smoke came out of there with pressure.
Old Jun 30, 2023 | 08:07 AM
Overkill2's Avatar
Overkill2
The early 6.7s, mine included, had no filter inside like Scott said. What may be happening is the bottom of the CCV where the "oil" is supposed to fall back into the engine is probably coked up from heat and blocked. You probably got many miles, err, kilometers on your truck I bet. You already buy a new one?
Old Jul 30, 2025 | 10:17 PM
Wyldfire's Avatar
Wyldfire
When I had dealership replace my CCV on my 2017 I asked to use a 2023+ and they did.
Old Jul 31, 2025 | 07:51 AM
Prezi68's Avatar
Prezi68
When I did mine, I removed the hot side pipe, and fuel filter as recommended in some videos. Some also recommend to loosen the fuel rail for the forward driver bolt on the ccv. I did not need to. This depends on the tools you have at hand. I replaced with the 23+ CCV. Mine is an 18. Good luck.
Old Jul 31, 2025 | 07:53 AM
Listor's Avatar
Listor
i get a code for mine quite often, 2014 6.7 is the 2023 compatible? I see it looks like a pain got get to
Old Jul 31, 2025 | 08:05 AM
Prezi68's Avatar
Prezi68
I believe the 23+ replaces all prior versions. If I am not mistaken 2011 has a sensor on it that the new ones do not. Check out a few videos on YouTube first. Check your local Ford stealer. I ordered mine from Extreme Diesel and saved $50.00. The back bolts are a PITA. The four bolts to the CCV are 10MM. I used a deep socket 10MM, 18" extension with a wobble on a 3/8" drive. Have fun and keep the cursing to minimum.
Old Jul 31, 2025 | 08:28 AM
Listor's Avatar
Listor
lMAO I'll try to remember that!
Old Jul 31, 2025 | 08:41 AM
Overkill2's Avatar
Overkill2
You mean the metal fuel line that runs to the CPP4? IIRC, there's a bolt there that holds them down, two lines, if memory serves me.
Old Jul 31, 2025 | 08:43 AM
Prezi68's Avatar
Prezi68
Correct. You don't have to remove them. Just enough to get the socket on.
Wardog686
Jan 22, 2011 08:02 AM
TxFordGuy
Jun 14, 2010 10:31 PM
lionsteve
Jan 22, 2007 10:15 PM
