Fuel filter questions
Old Jan 20, 2007 | 09:47 AM
lionsteve's Avatar
lionsteve
Which one gets the most votes here? The replacement filter or the one with the cap attached? Also who has the best price on filters? Again thanks in advance.
Steve
Old Jan 20, 2007 | 09:56 AM
nodakford's Avatar
nodakford
I like the replacement filter. Diesel Innovations is the cheapest I found for a filter.
Old Jan 20, 2007 | 10:21 AM
clintbonnie's Avatar
clintbonnie
My vote is for the replacement filter by racor and Geno's Garage (one of our sponsors) has them for $16.95.
Old Jan 20, 2007 | 02:06 PM
lionsteve's Avatar
lionsteve
It is on the way. Thanks
Steve
Old Jan 20, 2007 | 03:40 PM
mybigredford's Avatar
mybigredford
i always have been using the filters from ford (i was still under warrenty and didnt want to use any other type so there was no reason for them to deny warrenty) but now warrenty is off, and you guys think i can just buy filters from napa or wherever and the will be just as good?
Old Jan 20, 2007 | 06:43 PM
clintbonnie
i believe racor makes the ford fuel filters ( I am sure someone will correct me if i am wrong) and you get them from Geno's Garage at $16.95..
Old Jan 20, 2007 | 07:54 PM
CHPMustang's Avatar
CHPMustang
I been using the Racor cartridges for both the Excursion and on the 99,haven't purchased the filter/lid combo yet but should perform the same I'd assume.
Old Jan 20, 2007 | 08:51 PM
Sabre2th's Avatar
Sabre2th
I believe your right. I recall an article I read some time back that these motorcfaft filters were made by Racor because Racor designed our filter/separator unit for ford.
I have heard of some off-brand and sometimes the wix filters being too restrictive, and occasionally the ones with attached cap not sealing well.
Just my .02.
Tom
Black 1999.5 F250SD XLT AUTO 4x4 reg. cab(6/99), Pre-pump & Tank Mods, Racor Filter/Separator, HX Mod, ZooDad, WW, Power-pedal Mod, Pop-up gooseneck ball,Brush Guard, 3.5" lift, BFG Commercial AT tires (265/75), 65hp ATS chip, and #2 cologne. Ball joints replaced, and thinking about a BTM (or delete) and shocks....!
Drain valve repair write-up.
Old Jan 20, 2007 | 10:25 PM
ron's power stroke's Avatar
ron's power stroke
napa fuel filter part#3518 is what i use..its a wix filter..i get mine for 12 bucks..(inside sorse) but i think there around 20 bucks..
Old Jan 21, 2007 | 03:00 PM
RedDragon's Avatar
RedDragon
I have the Baldwin filters w/ attached lid. I haven't had any problems with them, but they are about $23 instead of $17 or so. However, I still carry the factory lid in truck just in case something happens and I need it.
Old Jan 21, 2007 | 03:10 PM
fxstbchopper's Avatar
fxstbchopper
I also use the one with the attached lid it cost me $19 don't have to mess with the o-ring or anything that way.
Old Jan 22, 2007 | 09:59 PM
Gradymeister's Avatar
Gradymeister
I bought a puralator with the lid attached the other day. Anything wrong with these?
Old Jan 22, 2007 | 10:15 PM
F250_'s Avatar
F250_
Racor filter element and new o-rings, re-using original OEM lid at 119,000 miles.
Just changed my fuel filter for the first time ever two days ago *just bought the truck in September). Never had a diesel before, either. Point is that with all the tips and suggestions from many folks on here, the change went perfect...
- no air in lines afterwards
- no screwed up o-ring
- lid went on straight and perfect first try
- not a single drop of fuel leaked either before or afterwards
- I even used coffee filters to filter the fuel drained from the bowl to put clean fuel back in before starting it up.
