Sponsored by: Real Truck
Code P0237
Old Jun 29, 2023 | 12:16 PM
robjs111's Avatar
robjs111
Code P0237
My 2001 f350 7.3 is pulling a p0237 code. Truck runs rough, bucks and sometimes stalls but restarts, check engine light comes on but for less than a min. Also battery light pops on but turns off right away. I replaced Map sensor and cps with a new motorcraft versions. Truck starts, idles and runs great except for issues mentioned above.
Thanks.
Old Jun 29, 2023 | 06:14 PM
Pickupmanx2's Avatar
Pickupmanx2
P0237 is an OBD-II generic code that is set when the powertrain control module (PCM) detects that the intake boost pressure sensor voltage falls below specifications. This may be due to a short in the wiring. The Boost Pressure Sensor tells the PCM how much boost is coming from the turbocharger/supercharger.
Have you looked under the hood for a short? Had a lil critter decide to chomp on some wires in my 02 F350/7.3 was able to repair them all, now I have outside cats for that problem..
Old Jul 5, 2023 | 05:12 PM
robjs111's Avatar
robjs111
P0237
All good now except for random stalling when truck is at idle warmed up.
Clear code but p0237 returns.
what else could be issue?
Thanks
yeterp
Aug 24, 2016 10:14 AM
f1501987
13
Mar 30, 2012 05:58 AM
Alpine6
Sep 8, 2007 10:28 AM
IM1096
Mar 29, 2007 09:02 PM
armantanzarian
1983 - 2012 Ranger & B-Series
May 17, 2006 07:01 AM
