Transmission problem
Old Jun 29, 2023 | 08:34 AM
akidd5777's Avatar
akidd5777
Alright I'm back again. 1991 ford f350 with a e40d. Had a new transmission installed. Do the return lines have a check valve on this truck. It's overheating and venting fluid.
Old Jun 29, 2023 | 09:49 AM
tecgod13's Avatar
tecgod13
No clue on check valves, but not sure why they would?
Did you flush the lines and cooler before hooking up the new transmission? Why did you replace the transmission?
Old Jun 29, 2023 | 10:38 AM
Prototypemech's Avatar
Prototypemech
There is no check valve. Your transmission cooler is probably clogged or one of the lines is crushed.
HT32BSX115
May 17, 2018 02:02 AM
brennanforgeron
Feb 2, 2017 01:45 PM
mattymax
Jun 11, 2015 08:49 PM
bigbubba87
Nov 25, 2010 01:22 PM
