Sponsored by: Auxito
cruise control not working
Old Nov 18, 2003 | 08:44 PM
fireguy's Avatar
fireguy
I Have a 98 f150 6cyl and the cruise control does not work.I have ckecked the fuses and the brake lights.i was advised if a brake light was inoperative it was cause resistance in the circut Any help is appreciated.
Old Nov 18, 2003 | 10:00 PM
JeremyH's Avatar
JeremyH
Have you checked under the hood to make sure that the CC cable is still attached to the throttle?
Old Nov 19, 2003 | 07:00 PM
fireguy's Avatar
fireguy
Jeremy,Ichecked the throttle cable and it was connected.thought i would try the clock spring connector.
Old Nov 22, 2003 | 12:35 AM
Eddieslilmule's Avatar
Eddieslilmule
Hey Fireguy, does your horn work, because its the same fuse as the cruise control. Thats how its on my truck, 97 F150
Old Nov 22, 2003 | 05:16 PM
fireguy's Avatar
fireguy
Thumbs up
My horn works.I as able to borrow a professional chiltons repair manual. I have checked the circut up to the vss switch. its either going to be the servo or switch.Didnt feel like crawling under the truck last night. I appreciate the input.
Old Nov 23, 2003 | 04:41 PM
fireguy's Avatar
fireguy
curise control problem solved. It was the brake pressure switch.
Old Nov 23, 2003 | 10:55 PM
Racerguy's Avatar
Racerguy
Thanks for letting us know what you found
