94 e350 e40d
Old Jun 27, 2023 | 06:56 PM
donintex's Avatar
donintex
4wd Low
94 e350 e40d
Have codes 624, 628 and 637. Where should I start? Fluid was recently replaced.
Old Jun 27, 2023 | 07:20 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The biggest problem is the 624 - Solenoid/circuit failure -Electronic Pressure Control (EPC) current is high. That could be a bad EPC solenoid, but most likely is a damaged wire between the PCM and the solenoid. Code 637 is TOT sensor is/was high or open. This is the same problem in a different circuit. Ignore the 628 for now. It may go away when the other two codes are fixed.
Old Jun 27, 2023 | 07:30 PM
donintex's Avatar
donintex
4wd Low
Hello Mark Kovalsky, thanks for the reply and info. I will check that and get back!
Old Jun 28, 2023 | 08:45 AM
manicmechanic007's Avatar
manicmechanic007
You should throw a like on Marks post donintex
+ 1 for that Mark
The trans harness inside the trans with the plug needs to be replaced most likely
Old Jun 28, 2023 | 08:00 PM
donintex's Avatar
donintex
4wd Low
Thank you guys! I checked plug and wires, I did not see any damage. I did not look very careful because the plug to the trany was not locked in by the plastic clips and it slid up easy. So I cleaded both ends and fully engaged plug, cleared codes, then drove about 50 milers and checked codes. 628 was the only code
Old Jun 28, 2023 | 10:19 PM
Mark Kovalsky
Since the 628 code reappeared I take it as a legitimate code. It means that slip was detected when the torque converter should be locked.
If the converter is really slipping it will discolor the front of the torque converter. Take the dust cover off of the bottom/front of the transmission bellhousing. Look at the front of the torque converter Is it the same color as the rest of the converter, or has it been blued? If there is bluing, the converter is slipping and needs to be replaced.
Old Jul 1, 2023 | 12:44 PM
donintex's Avatar
donintex
4wd Low
OK I will check that and get back. Thanks alot!
Old Sep 2, 2023 | 02:52 PM
donintex's Avatar
donintex
4wd Low
Hi Mark, hope you are still out there. I just checked the front of the converter and it looks the same as the rest of the converter. I should have also mentioned that a random, or as it seems to me, the van slip out of gear and then back into gear. this happens around 40mph +. But it can go months without doing it and then it may do it twice in one trip. I cleared the codes again and later checked them and got the 628 again. Thanks for your help. I am at a loss here.
Old Sep 2, 2023 | 05:56 PM
Mark Kovalsky
The random neutral is a bad MLPS (Manual Lever Position Sensor.) Replace it. It is located on the driver's side of the trans where the shift cable attaches. It's the part with the wiring harness. It's possible that this is also causing the 628 code. After it's replaced see if the code comes back.
Old Sep 3, 2023 | 12:23 PM
donintex's Avatar
donintex
4wd Low
Thank you very much. I will do that
Kyle Coit
Feb 14, 2026 05:29 PM
mastermind929
Computer Chips & Tuners
Nov 5, 2010 09:13 AM
thendrix
Feb 11, 2007 03:45 AM
Eric88xj
Car/truck Buying Advice
Apr 20, 2002 09:44 AM
