Sponsored by: Real Truck
Steering wheel adjustment
Old Jun 26, 2023 | 11:42 PM
Irtnog's Avatar
Irtnog
About 10 days ago I had my truck aligned. The steering wheel was flat and level when pointing straight ahead. Since then I’ve gone over Somme very rough roads. Now the steering wheel is canted about 15 degrees to the left when going straight. Do I need to get the truck realigned? Or is there a simple adjustment I can do?
Old Jun 27, 2023 | 01:03 AM
WWR's Avatar
WWR
Just adjust the length of the drag link from the pitman arm to the tie rod.
Old Jun 27, 2023 | 10:15 AM
5851a's Avatar
5851a
I would take it back, sounds like something was left loose.
Old Jun 27, 2023 | 01:46 PM
Pickupmanx2's Avatar
Pickupmanx2
Veteran: Marine Corps
I would tend to agree with this, nothing should move if done correctly...
Old Jun 30, 2023 | 08:03 PM
speakerfritz's Avatar
speakerfritz
You didn’t say what truck you gave.
on my truck, the adjust barrel is nearest to the pax wheel side. Yes it connects to the pitman arm, but on my truck, the adjust is on the other end of that link.
i spray penetrated mine to get the threads cleaned up.
my truck has a 3.5 lift in the front with a pitman arm drop kit and I thought I ran out of threads on the adjust barrel since it would not turn anymore. More penetrate spray and the barrel turned where I needed it.
do not forget to retighten everything
and…check bolt ends to make sure they are not close to hitting anything. I was close on contact so I cut some threads off so I had 1 thread beyond the nut instead of what looked like 5.
frysl
Jan 22, 2022 01:32 PM
eyemgh
Jan 12, 2022 12:53 PM
cameronskidoo
Jun 28, 2021 05:19 PM
jonrjen
6.7L Power Stroke Diesel
Feb 20, 2015 07:26 PM
m@m
2004 - 2008 F150
Apr 29, 2007 07:08 AM
