Sponsored by: Real Truck
Trailer Lights
Old Jun 26, 2023 | 09:38 PM
Slick collector's Avatar
Slick collector
Trailer Lights
Hey Guys,
I’m sure this has already been answered, but, I have a 2004 F-350, 6.0, a while ago, I hooked up to my horse trailer, I only had running lights, no brake or blinker, thinking I had a problem with the trailer, I rewired the whole thing with all new wiring and LED’s, put in a new 7pin connector on the truck, traced all the wiring on the truck from the connector to the block under the hood, tested everything with a light and ohms tester, can not find any issues anywhere other then no power, fuses are good, I also have a 99 with a 7.3, hook the trailer up to it and everything works, could I have a relay out in the under hood block? I don’t have much more hair to pull out
Old Jun 27, 2023 | 05:35 AM
projectSHO89's Avatar
projectSHO89
Check fuse F06 under the dash first. Verify it is ALWAYS HOT with a meter or test light if its condition is not obvious with a visual exam.
Old Jun 27, 2023 | 08:47 AM
Slick collector
I did that last nite, with a light, it’s hot and the fuse wasn’t blown, all fuses are good and they all have power, that’s when I started thinking it might be a relay in the block under the hood, wires are dead up to the block, with the exception of running lights, those work great.
Old Jun 27, 2023 | 10:24 AM
projectSHO89
It is important to include that kind of information so we know what has and hasn't been checked....and what the specific results were.
What exactly does that mean? Which wires and checked under what specific conditions?
Do the two trailer turn/stop relays click, individually for turns, both for brakes, when either a turn signal is activated or the brake pedal or hazard switch is activated?
Old Jul 25, 2023 | 04:51 PM
Slick collector
Problem solved
After a lot of tracing of wires I finally found the wire that controls brake lights and blinkers, it had been rubbing on the inner fender liner and was completely worn through, however it wasn’t visible until I took the fender liner out completely
explorer123
17
Feb 16, 2017 11:32 PM
kailor
Sep 4, 2011 12:22 PM
cobarjet
Oct 10, 2008 12:44 PM
countrysF250
Dec 2, 2007 06:14 PM
bluemoose89
Electrical Systems/Wiring
Dec 25, 2003 08:07 AM
