460 AC compressor/bracket
Old Jun 26, 2023 | 12:31 PM
TS F26's Avatar
TS F26
3rd Gear
I have a 79 f250 that was engine swapped with a 460 before I purchased it a while back. The truck has the factory AC box/vent plumbing. I’d like to fix the AC for when the 2-40 AC doesn’t cut it. From my understanding I just need the correct bracket/compressor, belt/pulley, and to plumb up the lines.
Is the bracket and compressor from a 73-79 351M/400 engine the same is the 460s?
Any info about 73-79 AC systems is welcome, thanks.
Old Jun 26, 2023 | 01:32 PM
tbear853's Avatar
tbear853
Compressor brackets for 351M/400 differ for 460. Compressor is same.
Is there an evaporator core and hoses with the AC box? You'll need a new expansion valve. You'll also need the condenser and new receiver drier for in front of radiator.
Guessing you'll use R134A?
Old Jun 26, 2023 | 02:30 PM
TS F26's Avatar
TS F26
3rd Gear
Thanks for the reply. It’s got a condenser and drier still mounted. It’s got lines run for what I assume is the heater core because the heat works. No loose lines from where a compressor would have been. Haven’t gotten far enough to figure out what refrigerant, but 134A seems like a reasonable choice.
Old Jun 26, 2023 | 05:33 PM
tbear853's Avatar
tbear853
I know, this is destroyed, but it shows both the heater core and the larger evaporator core in the AC box, as well as a heater valve in the heater hose that I forgot to mention. New ones are plastic, but they work.
If you want coldest air, you will need a heater valve to shut off flow of hot coolant to the heater core.
My heater valve, hoses, etc.
I've neatened it up, but the parts are there.
You'll need to replace the drier and expansion valve at least.
Old Jun 26, 2023 | 06:26 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Ha I took that pic and it is missing the blower motor....here is the way to cheat and replace the blower motor from the engine compartment. There are a few threads about it.
With the complete box removed.
Evaperator
Heater core behind it.
Blower motor behind it (already removed from the round hole.
Cruise this thread I have a lot of a/c diagrams in there. https://www.ford-trucks.com/forums/1...then-some.html
Old Jun 26, 2023 | 07:35 PM
79F150400M's Avatar
79F150400M
Idler pulley bracket
Compressor bracket
If these are what your looking for...PM me and I'll make you a sweet deal. I removed them from a 76 F350 with a 460.
Edit:
Tried to PM you...I see your a new member and you need to post more to be able to PM other members.
Old Jun 26, 2023 | 08:04 PM
tbear853's Avatar
tbear853
I thought you did, and when I stole it I knew you did. It is revealing.
josiewales
Apr 3, 2022 09:18 PM
ManfredVonRichtofen
WTB - Parts & other
Jan 1, 2016 11:45 PM
75Three90
Mar 15, 2010 10:37 PM
mustangman
Jun 2, 2006 10:38 AM
duck
1978 - 1996 Big Bronco
Apr 26, 2000 08:18 AM
