Very smokey startups
Old Jun 28, 2023 | 03:27 PM
knottyrope's Avatar
knottyrope
cant measure GPs OHM when harness is connected since its a parrlell circut and the lowest one gives you a reading.
there should be about .1 ohms at the GPR between the two big posts, higher than .1 and you have a GP that is burnt out.
Measure the GPs OHMS at the UVCH unlugged to ground
Old Jun 28, 2023 | 03:37 PM
DanielT28's Avatar
DanielT28
I guess I’m not understanding what you mean by Unlugged? I unplugged the pigtail. Touched the multimeter (-)to the block. And the (+) to each GP at the connector truck side
Old Jun 28, 2023 | 05:59 PM
Hit Man X's Avatar
Hit Man X
If starts at 55F not plugged in, most if not all GPs are working. Mine would not start under 60F with the GPR unplugged. 65F was about the threshold for mine.
Plugging in is a quick test. 3-4hr seems sufficient to me.
Old Jun 28, 2023 | 08:26 PM
97-psd's Avatar
97-psd
I am not in agreement with this. My GPR is currently disconnected and it seems to start fine so far down into the 50s without any help. I think compression has an impact on it.
sounds like you are testing the GPS correctly
Old Jun 28, 2023 | 08:29 PM
97-psd's Avatar
97-psd
I like testing at the IDM connection. It helps to make sure everything is in good order from the IDM to the injectors.
Old Jun 29, 2023 | 10:19 AM
knottyrope's Avatar
knottyrope
i meant unplugged, typo
OK that is good to do it that way.
Old Jun 29, 2023 | 02:39 PM
PriusLover's Avatar
PriusLover
Originally Posted by z31freakify
how's the blow by? Any movement when you flip the oil cap on the oil fill hole? (cap vibrating off is ok, but pulsating means bad)
Cap flip test can only indicate an outright fail, not a pass. Like yeah do it and if it gets puffed off that's very bad, but can't assume blow-by is fine if that doesn't happen.
I will get to the compression test...
I'd recommend doing a running compression test vs just a standard cranking. You can get perfectly fine cranking numbers across all cylinders even if dusting/wear has occurred to the extent that it's causing problems. IIRC you want to see ~600-650 PSI.
Old Jun 30, 2023 | 01:18 PM
DanielT28's Avatar
DanielT28
Originally Posted by fordman67
How long does it take to stop smoking?
Plug it in then see how the morning start goes. If it changes it then you may have gp system issues still.
If the truck runs ok after a lil heat and does the job needed, how far do you really need to go? It may not be perfect but at almost 25 years of use...none of em are. Just playing devils advocate here.
i need to try plugging it in still
Old Jun 30, 2023 | 02:49 PM
knottyrope's Avatar
knottyrope
does oil cap when placed upside down blow off at idle?
what about at 1k RPM, 2k and 3k?
Old Jun 30, 2023 | 04:07 PM
DanielT28's Avatar
DanielT28
I’ll check it when I get home. On vacation currently 🤘
Old Jun 30, 2023 | 08:57 PM
brokestroke's Avatar
brokestroke
My OBS smokes just like yours. Cold calm mornings it will be a plume that could cover over half a football field. It uses a little bit of oil but no more than my other 7.3s that don't smoke. It has a raw fuel smell that will burn your eyes but always goes away once warm. Oil cap blow-by is zero and won't push the cap off the filler neck even at 3000rpm. Good glowplugs and will start in sub 0 temps no problem. No lack of power or other symptoms. It has smoked like that for over 15 years. Always thought it was fuel timing.
Old Jul 1, 2023 | 12:51 PM
DanielT28's Avatar
DanielT28
well. This is reassuring. 😆
Old Jul 6, 2023 | 10:56 AM
  #28
DanielT28's Avatar
DanielT28
Pulled the turbo yesterday. No major Leaks. Possibly on the compressor side. But I can’t tell whether it was the seal or CCV. I snapped 2 bolts pulling the turbine housing. Ordered a new one after failing to extract it. Broke 2 extractors. Turbine housing and housing was a B to separate.
I don’t see any obvious issues with it. But hopefully fresh seals helps the smoke. Also grabbed a RR diesel 4/4 compressor wheel and a western snow plow GPR. 360° thrust bearing rebuild from RR diesel
Old Jul 6, 2023 | 11:10 AM
  #29
knottyrope's Avatar
knottyrope
only the exhaust side seal leaking will make blue smoke
intake side leaks and CCV will burn off in the combustion chamber unless you have a dead hole
maybe do compression test while in there?
Old Jul 6, 2023 | 11:17 AM
  #30
DanielT28's Avatar
DanielT28
Also, does anyone have any tips for getting the t4 bolts tight on the turbo when I re install? I pulled the turbo a few months back to do the up pipes. And the 2 lower bolts weren’t loose. But they also didn’t take much effort to break loose. The new bolts with the up pipes are 13mm. So I used a box end wrench to get in there this time
