Axle swap
Old Jun 26, 2023 | 06:56 AM
lbicknese2005's Avatar
lbicknese2005
Trailering
Axle swap
Im looking to do an axle/suspension swap on my 89 f150. The axles and suspension I want to put under it are from an 87 250. I was curious if i would have any problems or what it might entail
Old Jun 26, 2023 | 08:35 AM
jas88's Avatar
jas88
Is your truck 4x2 or 4x4? Is the F250 4x2 or 4x4?
Old Jun 26, 2023 | 11:12 AM
BlackBeautyFlareside's Avatar
Just my .02 here but if you're going through the trouble of swapping axles, a solid front axle would be a premium upgrade. Below is a 78 or 79 Dana 44, however if you want heavy duty axles, a leaf sprung Dana 60 would be a good choice.
https://www.ford-trucks.com/forums/8...ml#post8008240
Old Jun 26, 2023 | 11:27 AM
Scndsin's Avatar
Scndsin
See this thread & go from there:
https://www.ford-trucks.com/forums/1...otor-swap.html
Old Jun 26, 2023 | 11:30 AM
hav24wheel's Avatar
hav24wheel
IMO, 05 up superduty axles would be the easiest swap being yours already has coil buckets installed.
Old Jun 26, 2023 | 06:23 PM
lbicknese2005
Trailering
both are 4x4
Old Jun 26, 2023 | 06:24 PM
lbicknese2005
Trailering
i plan to use the heavy duty axles because they are available to me and are free but thank you
Old Jun 26, 2023 | 07:17 PM
rla2005's Avatar
rla2005
Not exactly an easy swap. Your F150 has coil springs, the F250 donor has leaf springs. Boxing the front frame rails is just the beginning.
Same transmission in both trucks?
Old Jun 26, 2023 | 09:22 PM
hav24wheel's Avatar
hav24wheel
The F250 front axle might not be any better than what you have. Some where D44s some where D50s.
Old Jun 27, 2023 | 08:15 AM
manicmechanic007's Avatar
manicmechanic007
Go for it
It can be done
Old Jun 27, 2023 | 01:13 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Go for it
It can be done
No one said it cannot be done. Is there a benefit in going from a coil spring F-150 Dana 44 TTB to what might possibly be a leaf spring Dana 44? What is the purpose of removing the 8.8 for a 10.25(?) unless the OP really needs the larger ring and pinion for off road use/big tires? Putting 3/4T axles doesn’t now make it a 3/4T truck.
Old Jul 28, 2023 | 10:14 PM
lbicknese2005
Trailering
No. the 250 is a manual and the 150 is an aod
Old Jul 28, 2023 | 10:15 PM
lbicknese2005
Trailering
how could a guy tell the difference?
Old Jul 28, 2023 | 10:26 PM
85e150's Avatar
85e150
Body swap will end up with better results.....
Old Jul 28, 2023 | 11:14 PM
hav24wheel's Avatar
hav24wheel
the lockouts will be the same size as your 1/2 ton lockouts. The D50 has same lockouts as a D60.
