What is the correct spark plug
Old Jun 22, 2023 | 12:21 AM
johnnymac001's Avatar
johnnymac001
Hello Everyone
I would like to ask for your comments on which are the correct spark plug for my 1995 Ford f150 5.8 litre vehicle.
I recently purchased a set of Motorcraft spark plugs which I would like to use in my vehicle.
The purchased spark plugs are SP-493-X (AGSF-32P-MX). These have a reach of 0.679, (5/8) inch. However when I started to remove the old spark plugs, what I removed were Autolight 24 and they have a 0.5, (1/2) inch reach. Upon checking auto parts store most want sell me the shorter reach plugs and say the the SP-493-X plugs are a wrong fit. I presume that this could be a copper core vs platinum core and heat range issue?
However I woud appreciate your comments and read what you consider to be the correct and best spark plugs for this vehicle.
Thank you
John
Old Jun 22, 2023 | 06:14 AM
2dwoods's Avatar
2dwoods
I'm no help but I've noticed it before its been so long since I've changed my plugs I can't remember which I have but I think auto light because I was worried about the long one hitting .I'm interested in learning the diff.
Old Jun 22, 2023 | 07:25 AM
Scndsin's Avatar
Scndsin
I can't remember the # listed on the emissions sticker under the hood, but I know it has changed. (Thanks Mototrcraft)
Can't look at mine either, right now or I would.
If you go to the Motorcraft site & enter that #, I believe it will give you the current version #. (copper, I believe)
Most of us don't use platinum, and there is a absolute record of "many" of this gen engines running like crap with them & doing fine when changed back to copper.
YRMV.
Old Jun 22, 2023 | 07:37 AM
FuzzFace2's Avatar
FuzzFace2
As said look up what plugs your truck / motor should have and if you dont see the plug you have listed dont use it.
Also if it is not copper dont use it. Same if it is longer dont use it.
If they are left over from your Kia, etc. dont use them.
See where we are going here ........ yep dont use them and get the right ones in copper!
Dave ----
Old Jun 22, 2023 | 08:05 AM
manicmechanic007's Avatar
manicmechanic007
ASF 32 P?
SP 501 Motorcraft platinum
What does the underhood sticker say?
I do know that if there are clearance issues when you install the new plugs
It will touch the pistons barely enough to shut down the gap on a few cylinders and miss like hell
Never done it, just seen it happen at the dealer
The old plugs were short right?
Find New Old Stock double platinum plugs on Ebay?
Old Jun 22, 2023 | 08:29 AM
FuzzFace2's Avatar
FuzzFace2
None of our trucks used platinum or the other fancy plugs they have today.
It has been known that they can cause running issues and why you want to use copper.
Besides the under hood sticker has copper, as them fancy plugs were just coming on market and only used it high end cars at the time.
Dave ----
Old Jun 22, 2023 | 09:00 AM
manicmechanic007
You use copper if you want
I use the double platinum plugs in mine due to the longer interval
Old Jun 22, 2023 | 09:04 AM
manicmechanic007
Running a Platinum plug instead of a Copper will not cause any drivability problems
Been running them in my 1994 vans for years and years
Old Jun 22, 2023 | 09:16 AM
Scndsin's Avatar
Scndsin
Running a Platinum plug instead of a Copper will not cause any drivability problems...
Yep. That's what a lot of folks say.
Old Jun 22, 2023 | 09:46 AM
manicmechanic007
There must be a reason for that Scndsin
Have you ever looked at an ASE master tech exam?
Old Jun 22, 2023 | 10:04 AM
1Butcher's Avatar
1Butcher
I've worked on German cars for 40 years and it is weird, some engines like certain plugs. It really should not matter, but it does.
If you lit match full of gas and air, does it matter what will happen? I think not. That is what I think a spark plug does. I have seen it personally, use the plug that works for you. If it is the fancy $20 plug or the $2 plug.
Couldn't you measure the depth of the plug hole and find out what physically fits?
Old Jun 22, 2023 | 11:53 AM
Scndsin's Avatar
Scndsin
No I have not.
But I have read dozens & dozens of posts/threads here over the years that basically go something like:
Did tune-up/now truck runs like crap/ran fine before. When quizzed, response near universally is "went with platinum".
When encouraged to go back to copper & they DO... problem invariably disapears.
I'm quite certain that itty-bitty, expensive-assed, never should wear out electrode SHOULD be just the same as that big fat cheap one that burns away, but for some of this gen & age, it just AIN'T.
As posted before...
Your Results May Vary.
Old Jun 22, 2023 | 12:10 PM
Hit Man X's Avatar
Hit Man X
Oft those old euro cars need non resistor plugs as they are in the wire set or some spec a certain plug due to the cam/combustion chamber design.
Those Bosch +4 are common for odd driving issues in my experience. I wonder if a basic Pt plug (single strap) with correct gap would be fine where a copper was used. Probably.
Anyway, just go to your local auto store and order your brand. I like Champion or NGK.
Old Jun 23, 2023 | 10:39 AM
1Butcher's Avatar
1Butcher
There are thousands of threads never made that could say. I did a 'tune up' and put in platinum plugs and everything is running well.
People come here where there are problems. Very rarely is there a thread that just indicates their truck is running fine. Working in dealership service departments for 30+ years, it was the same way. Every client that came in the door had a problem. No one ever came in and said, 'Everything is fine, just thought you should know'.
As a diagnostic tech, I take statements like platinum plugs with a grain of salt. I have a Kenne-Bell supercharged 5.8l and it had platinum plugs for 15 years and never had a problem. Not saying it was right, but it worked for me. Not certain what's in there now.
I do know, we have a choice. I prefer OEM parts. As a show owner, I have much less comebacks and if the car goes to the dealership for any issues, there is a lot less blame on the parts I use.
If you think copper is better, just do it. It would be stupid for anyone to put in parts they have no faith in.
The next thing we should figure out is what the best oil and filter to use.
Old Jun 23, 2023 | 11:55 AM
My4Fordtrucks's Avatar
My4Fordtrucks
As previously mentioned the spark plug number is on the emissions sticker under the hood. You could use that to see if it is still available or there is a superseded number. I recall reading in a thread that Ford changed to platinum plugs around ’94 or ‘95?
