Sponsored by: Real Truck
Grounding Wiring Question
Old Jun 21, 2023 | 11:00 PM
reptar0077's Avatar
reptar0077
On a 2003 F-250 5.4
New starter on new engine.
Old negative battery cable is bad.
The original negative cable goes from starter to frame then to negative battery terminal then to side truck frame right next to battery negative.
(Bolt with terminal spliced into cable between starter & battery.)
Can I run a new one from the starter negative to negative battery terminal then to side of truck skipping the larger frame negative below it?
If I have to I can solder in a splice off to go to larger frame ground.
Thanks!
Old Jun 22, 2023 | 05:47 AM
user 195474726373's Avatar
user 195474726373
I don't see any problem with that.
Negative Covfefe
Jan 18, 2022 03:15 PM
Negative Covfefe
13
Jan 10, 2022 05:03 PM
bkgeig
Dec 16, 2016 11:42 AM
Navydawg
Mar 12, 2009 09:54 AM
brent91
Sep 5, 2004 01:42 PM
