Sponsored by: Real Truck
Another instrument question
Old Jun 20, 2023 | 01:51 PM
aquadave's Avatar
aquadave
2003 F350 gas. My cluster went out yesterday. I spent hours checking fuses and looking on line, no luck. No blown fuses. I went out later and they worked. This morning they blipped but started working. My question, Is there a particular ground wire I should check and where is it? I'd like to be sure before replacing the cluster
Thanks
UPDATE
It did it again. Out for a couple days. I used the dash light dimmer up and down turned on the dome light Bam they started working. To be clear they started working when I turned the light on while the truck was running. They were not working as soon as I turned the dome light on, they worked. Still confused though
Roady1269
Jun 20, 2023 08:54 AM
dlibson
Mar 7, 2010 10:28 PM
bart f-350
Electrical Systems/Wiring
May 8, 2009 08:51 AM
N_fini_T
Feb 26, 2003 10:01 AM
