Fuel pump filter replacement
Old Jun 14, 2023 | 05:52 PM
dadgonebroke's Avatar
dadgonebroke
I noticed a leak from my fuel pump filter canister that's part the fuel pump. Ethanol had gummed up and ruined the o ring. I unscrewed the canister off to make the exchange, fuel poured out of the pump and continued until I made the exchange. It lost quite a bit of gas and would have drained the fuel tank. I changed the fuel years back and I don't remember it being this messy a job. Logically fuel is gravity fed from tank to pump but I don't remember it being this messy a job when last done. Sorry for the stupid question!
Old Jun 14, 2023 | 10:32 PM
Bob Ingram's Avatar
Bob Ingram
That doesn't look like my pump, mine has a clear glass bowl.
That said, I always shut off the gas petcock before I do anything on the fuel system.
Good luck
Old Jun 15, 2023 | 08:45 AM
dadgonebroke
Good luck
Gas petcock? Where?
Old Jun 15, 2023 | 09:35 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
48/52 has a 7HC-9189 petcock shutoff at the base of the tank.
The pictured pump looks to be for a 55/56 and there doesn't appear to be a listing for group 9189 for those years. One can certainly add a generic brass fuel shut off valve.
Old Jun 15, 2023 | 09:50 AM
52 Merc's Avatar
52 Merc
It sounds like you "got lucky" and created a siphon when you dropped the filter canister this time, just like sucking on a garden hose. A simple vice grip clamping the rubber connector hose from the hard line to the pump would have stopped the flow. Something to remember next time.
Old Jun 15, 2023 | 10:15 AM
ajsunnyB's Avatar
ajsunnyB
All the previous post are right on, I have a shutoff valve I installed the filters I buy from NAPA there is a small o ring and the filter has a nipple ring. I put the filter on the inlet then install the cap. That pushes the filter in place. I also use fuel lube. On all the o rings. This corn fuel additive they put in fuel these days will attack the orings the fuel lube will kinda protect the orings. And delay that decay. Just my opinion. I also cost the top of the filter can. To get a good seal.AJ
MSCPackers66
Feb 12, 2017 06:40 PM
caedes
May 31, 2015 02:58 PM
terrynbama
1983 - 2012 Ranger & B-Series
Oct 12, 2011 08:07 AM
tHeCoS
Nov 14, 2004 10:57 AM
