Motor mounts?
Old Jun 13, 2023 | 09:01 AM
willie71's Avatar
willie71
Motor mounts?
I followed the diagram for these particular mounts, got everything in and I started to put large washer on first but it was too large and was not laying flat because of mounting arm had high points on the sides. Should I get a smaller washer for underneath top washer or will the one washer suffice?
Old Jun 13, 2023 | 09:45 AM
CharlieLed's Avatar
CharlieLed
Looks perfect to me...
Old Jun 14, 2023 | 05:37 AM
ajsunnyB's Avatar
ajsunnyB
If I remember right that large washer goes between the rubber mount and the engine. The small washer is correct see the bottom washer plate. The top of that mount will have a impregnated washer in the rubber if I remember that large washer goes on top of that. I coated that washer with a thin coat of Lubriplate. AJ
Old Jun 15, 2023 | 09:43 AM
willie71's Avatar
willie71
Motor mounts 51 f2
So basically I need to put the large washer on top of rubber and under motor mounts?
Old Jun 15, 2023 | 10:29 AM
ALBUQ F-1's Avatar
ALBUQ F-1
The way it is shown in your picture is correct. Assuming you have the correct bolt, tighten it until it bottoms on the shoulder to properly preload the rubber.
Old Jun 15, 2023 | 01:41 PM
ajsunnyB's Avatar
ajsunnyB
Ya my other owner has a49 6 cylinder and that's the way we installed th motor mount.
Old Jun 15, 2023 | 04:38 PM
willie71's Avatar
willie71
Motor mounts 51 f2
I'm not sure from the responses if to use the large washer or not. In the photo, I have the large washer not being used. One says to leave as shown in photo without large washer. One says to put large washer on top of rubber under motor mount. What is the consensus from everyone which way it should it go? Maybe I'm just having a brain fart day?
Old Jun 15, 2023 | 05:56 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Use the washer that is installed, not the bigger one.
Old Jun 15, 2023 | 08:27 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
From the Ford illustration:
Old Jun 15, 2023 | 09:00 PM
willie71's Avatar
willie71
Motor mounts 51 f2
Yep. That's the image I was working from originally. It would be nice if the illustrations I've found and this one, showed the actual motor mount and if the large washer goes on top of rubber or on top of motor mount. I think it would make more sense having the large washer on top of rubber under motor mount to make the rubber last longer. I think I'm going that route.
Old Jun 16, 2023 | 02:09 PM
willie71's Avatar
willie71
Motor mounts 51 f2
I wonder why there is an asterisk by the large washer in diagram?
Old Jun 16, 2023 | 02:28 PM
bmoran4's Avatar
bmoran4
It means that particular part group is/was not available for separate sale from Ford back in the day.
lunghd
Large Truck
Apr 20, 2023 06:15 PM
mdlave
Ford Truck Parts for Sale
Jul 12, 2016 07:56 AM
Gigemags05
Jul 11, 2015 07:45 AM
kooper909
Oct 12, 2007 06:19 PM
Gary E
Mar 1, 2007 02:22 AM
