Engine problem help
Old Jun 10, 2023 | 04:18 PM
Weatherwalk's Avatar
Weatherwalk
Engine problem help
I have a 78 with a 302 that was freshly rebuilt. I just finished the cam break in a few days ago and I’ve now noticed a pretty bad miss and some white smoke out of the exhaust. I checked the plugs and all were fine except for cylinders 3 and 4. The plug on 3 was fouled and the plug on 4 was wet. Swapping the plugs did not change anything. I removed the valve cover and started the engine and could visibly see the valves opening and closing. The rockers are still tight as well. What should my next steps be?
Old Jun 10, 2023 | 04:21 PM
85e150's Avatar
85e150
Head gasket. Pull the head, check for issues, replace the gasket.
Who did the rebuild and is there a warranty?
Old Jun 10, 2023 | 04:27 PM
Weatherwalk
Unfortunately no warranty as I did the rebuild myself to save money
Old Jun 10, 2023 | 04:42 PM
aquanaut20's Avatar
aquanaut20
before you start tearing the engine down,
Perform a cylinder pressure test,
perform a cylinder leak down test.
If you have access to a scope, run a primary and secondary wave for on the sparks and a wave form on the injectors
Lets gather evidence rather than guesses..
Old Jun 10, 2023 | 04:46 PM
Weatherwalk
No injectors as it is a carb engine. But I can go get a pressure tester and check that out
Old Jun 10, 2023 | 06:18 PM
Viper Pilot's Avatar
Viper Pilot
This may sound gross, but it’s a good way to check as to whether or not you have a head gasket leak and coolant is coming out of the exhaust.
Run it for a little while, dab your finger on the end of the tailpipe and taste it. Yep, stick it on your tongue. If it’s sweet, there’s coolant present. Spit a few times and then go grab a beer and spit a few swigs out. Hopefully no one notices.
Old Jun 10, 2023 | 06:24 PM
tbear853's Avatar
tbear853
Sounds like a head gasket.
What kind did you use, what was the prep?
Also .... if you feel the urge to mess with a lifter, make sure the same lifters go back in the same lifter bores as they come out of. Should not need to, but "if".
Old Jun 10, 2023 | 06:33 PM
jflem's Avatar
jflem
Your nose can tell you what is coming out the exhaust. Just smell the smoke, oil and coolant are obvious. Then you can figure your next step.
Old Jun 10, 2023 | 07:01 PM
Weatherwalk
I used fel pro head gaskets, can’t remember the exact ones off the top of my head. Head and block surfaces were cleaned completely with scotch brite and wiped down with alcohol and dried prior to installing. Heads were placed on and tightened in the proper sequence to spec
Old Jun 10, 2023 | 07:09 PM
440 sixpack's Avatar
440 sixpack
Is there water in the oil or oil in the water? it should be drinking water a little if it's a gasket. could be an intake gasket, if it is you should have water in the oil .
Oil fouled plug or washed out ?
Antifreeze is murder on bearings, don't run it until you get this resolved. I always break in on pure water and run it a while before I add antifreeze just for times like this.
Old Jun 10, 2023 | 07:14 PM
Weatherwalk
One plug was just covered in carbon and the other one smelled like gas. I checked the oil with the dipstick and it looked like normal oil. Didn’t see any milkshake
Old Jun 10, 2023 | 08:17 PM
Old Guy F-250's Avatar
Old Guy F-250
Question,,,
Did you have the heads magna fluxed
Did you have them re surfaced or checked for warpage?/
probably head gasket white smoke....
Old Jun 10, 2023 | 08:28 PM
Weatherwalk
Originally Posted by Old Guy F-250
Question,,,
The heads are a set of GT40s that I bought from a friend. I was told they were recently redone and they looked good. They have new trick flow springs, seals and retainers and the valves were lapped in. They could be warped but I doubt it
Old Jun 10, 2023 | 08:34 PM
440 sixpack
What carb? you might be loading up on fuel. normally gas is black smoke but if you're dumping raw fuel it can make a mess.
Your oil might smell like gas. trying another carb would be a simple test if you have one.
Old Jun 10, 2023 | 08:40 PM
Weatherwalk
I don’t have another carb to try. The carb on the engine is a brand new Brawler 650 with vacuum secondaries and an electric choke.
