12" screen swap
Old Jun 8, 2023 | 04:48 PM
kevscamaro's Avatar
kevscamaro
4wd Low
12" screen swap
anyone seen a write up on swapping a 12"screen from a newer f150 into a 23 super duty . ?
Old Jun 8, 2023 | 07:33 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
You'd be better off swapping a super duty 12" screen and module, plus all the center stack dash pieces.
Old Jun 9, 2023 | 09:11 AM
110 Motorsports's Avatar
110 Motorsports
I have the same question. The 2023's all have Sync 4, trying to determine if now a 12" screen is the same in all the trucks. Then just finding the right bezel.
Old Jun 9, 2023 | 09:30 AM
kevscamaro's Avatar
kevscamaro
4wd Low
Im assuming the f150 and the superduty use the same 12" screen and module.
there is a write up on youtube installing a 12" from an 8" in an f150. Looked pretty straightforward. Theres alot of f150 stuff for sale out there.. would just like someone to confirm before i drop the cash.
Old Jun 9, 2023 | 09:37 AM
110 Motorsports
The dash piece from a F150, looking at them aren't going to have a engine brake button if you have a diesel. I do.
Would think the screens would be the same though.
Old Jun 9, 2023 | 10:08 AM
kevscamaro's Avatar
kevscamaro
4wd Low
I know the dash trim is different. I would need to order that piece. The buttons are reused with the new trim piece.
Old Jun 9, 2023 | 10:22 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Check witha Ford parts site and see if the part number for the screen is the same between F150 and super duty.,
Old Jun 9, 2023 | 12:36 PM
110 Motorsports
Closest I've found so far. Cable. Multi Function Display 12". | FordUS That's for a cable, but it seems the display is part #10D885 (This may be for the 8" even though it looks like the 12" on the site.) this is for a 2023 F450 Lariat. A
Old Apr 26, 2024 | 12:40 PM
Donald B's Avatar
Donald B
Trailering
Status
Has anyone attempted this and had success? F150 Screen the same?
Michaeloh
Jun 4, 2019 11:09 PM
dwood78
Jun 4, 2019 05:58 PM
Brad Brown
Engine Swaps
Jan 3, 2017 07:31 AM
jerem0621
Dec 31, 2012 07:10 PM
