A/C Compressor Electrical Issue
Old Jun 13, 2023 | 03:09 PM
CousinCarl's Avatar
CousinCarl
If you have power at the passenger side upper most plug, you're issue is down stream. There's 3 wires in this pigtail ([1] in my pic I found on the internet). A black, red, and tan/green tracer. The red will feed the lower pressure switch [2] along with another red with yellow tracer. If sensor is good, it will divert power to the high pressure switch [3] (red with yellow tracer and tan/green tracer wire). Compressor [4] is fed by that black wire (ground) and tan/green tracer.
As udsuth78 mentioned, there's some splices along this route. Sous sent me this diagram that helped me as well. Happy hunting.
Old Jun 13, 2023 | 03:12 PM
udsuth78's Avatar
udsuth78
Originally Posted by CousinCarl
There's another power distribution box under the hood by the hydroboost. The pictured diagram is in reference to this box, not the box under the dash.
He's working on an 02, no under hood power distribution box.
Old Jun 13, 2023 | 03:26 PM
CousinCarl's Avatar
CousinCarl
Oof!... disregard.
Old Jun 14, 2023 | 11:12 AM
kbeefy's Avatar
kbeefy
OK, just got a chance to look at a schematic.
^^^ That diagram sucks... let me see if I can get a better one....
The switches all feed the pcm, the pcm chooses when to excite the relay, and the relay sends batt voltage to the clutch.
Do you have a good ground to your AC clutch? I know you mentioned jumping it to the battery, was that just positive or positive and negative?
The AC relay is in one of those little relay boxes under the hood. It's coil is fed by fuse #23, and ground is supplied by the PCM.
The relay gets it's main power from fuse #10, which should be hot at all times.
Old Jun 14, 2023 | 11:21 AM
kbeefy's Avatar
kbeefy
Lets see if either of these work.... I always have a hard time uploading schematics.
Oops... only one was the proper format.
File Type: pdf
Old Jun 14, 2023 | 11:27 AM
kbeefy's Avatar
kbeefy
Almost got it all in a screenshot....
Old Jun 14, 2023 | 12:41 PM
udsuth78's Avatar
udsuth78
That's a lot of spaghetti just to stay comfortable in your ride.
Old Jun 14, 2023 | 01:39 PM
kbeefy's Avatar
kbeefy
That's simple... try adding dual climate, rear heat and ac with controls.....
Old Jun 14, 2023 | 01:56 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Is that diagram from AllDataDIY?
Old Jun 14, 2023 | 02:06 PM
kbeefy's Avatar
kbeefy
No, prodemand, which is the shop management system (Mitchel) from snapon.
I prefer their wire schematics to alldata. I haven't seen alldatadiy schematics, but I assume they're the same as alldata.
Old Jun 15, 2023 | 07:16 AM
FordTruckNoob's Avatar
FordTruckNoob
I'm so jelly. I can't justify the cost of the pro stuff since I don't/didn't own a shop like you do/did.
Old Jun 15, 2023 | 09:26 AM
kbeefy's Avatar
kbeefy
I would love to find a more affordable option. I'm lucky enough to be friends with the person that I sold my shop to, and he shares his account with me.
Old Jun 15, 2023 | 10:58 AM
  #28
udsuth78's Avatar
udsuth78
Do you know how I know you're gay? You use the word jelly not referring to the delicious condiment meant for biscuits and peanut butter sandwiches. Not judging though. What you do in the privacy of your truck is no concern of mine.
Old Jun 15, 2023 | 01:21 PM
  #29
FordTruckNoob
I wuv you too dahling.
Old Jun 15, 2023 | 01:35 PM
  #30
jstihl's Avatar
jstihl
QUO
insert Jim Carrey " Oooooo Biiiiillllyyy"
