Long Crank - ICP zero pressure for 20 seconds of cranking
#31
This is just a odd problem , there is only so many things it can be. Just taking a shot in the dark here but you said it has a DP tuner on it so what about putting the tuner on stock programming and disconnect it from the OBD-2 port ( if it's that type) and try to start it on stock PCM programming. Single shots will run on stock programming just not that great, it won't hurt anything. Just to see if you still get the 20 second crank. I know it's probably not the problem but it's free, quick and easy. The pigtail needs to be fixed anyways so probably a good idea to go ahead and do that.
#34
#35
What's going on with the low oil pressure? As long as you're reservoir is staying full the low oil pressure pump should be fine. You did say that the reservoir does not bleed down correct?
#36
Originally Posted by jstihl;[url=tel:20875882
20875882[/url]]What's going on with the low oil pressure? As long as you're reservoir is staying full the low oil pressure pump should be fine. You did say that the reservoir does not bleed down correct?
#37
96ford250
13
05-08-2013 11:09 PM
NeXguy
09-03-2010 10:18 PM
