Long Crank - ICP zero pressure for 20 seconds of cranking
I'm working on my brother's 7.3L that long cranks before starting (20 seconds typically), diagnosing with Forscan and viewing the IPR % values along with the ICP Pressures. It shows zero ICP pressures while cranking the first 20 seconds, the IPR will go all the way to 65% (wide open) while cranking, once pressure shows up on data, the truck starts and idles fine (700-850 psi at idle). The HPOP reservoir does not drain down at all even after sitting for a long time but it seems like the oil galleys in the heads are losing prime possibly, or maybe an injector o-ring is leaking slightly. This issue will repeat itself within five minutes of shutting down the truck as well. It fires right back up fine if you start it withing 30 seconds of turning it off.
Is this a typical injector o-ring issue?
How else can those oil galleys not show a little pressure right as you start to crank? The HPOP has it's own reservoir and the HPOP was recently replaced.
Is there oil in the icp connector?
Maybe try disconnecting the ICP sensor to see if anything changes
This is something I rigged up to put shop air to the HPO lines going to the heads, just disconnect a line from hpop and screw it on to this and pump it up with air. This is for JIC fittings but if you have the original quick disconnect fittings you can drill and tap an old fittings if you have one around. Other guys have had luck just putting a blowgun straight into the HPO fitting on the head and holding it there injecting air in but I have a hard time doing that so I rigged up this contraption. Seems like it's either an electrical issue or you have some kind of very minor leak that is allowing the oil galleys to leak down when engine is off. I'm sure others will be a long shortly to offer some additional advice
Originally Posted by jstihl
Wonder if maybe the oil galley drain plugs blew an o-ring?
So, I just tried putting shop air into the injector line ports in the head. I used the rubber tipped blow gun approach. Both sides seem to hold pressure but I'm not applying that much pressure I don't think. When I let off the pressure on the blow gun, an audible hiss of air pressure relieves. Do I need to apply 100+ pounds of shop air to that galley to actually test the o-rings?
Ball valve also aids in relieving the pressure, forgot to close the ball valve one time when disconnecting the shop air hose... That didn't turn out so well lol.
