Trans cooler lines
Old Jun 6, 2023 | 10:04 PM
Dodgeyaussie's Avatar
Dodgeyaussie
Trans cooler lines
Would anyone have a pic of the correct routing for the trans cooler lines? Mine are a mess. I tried to find some pre-bent ones without luck, So I might just try and make my own.
Old Jun 7, 2023 | 04:27 AM
Crop Duster's Avatar
Crop Duster
If you are going to use a radiator trans cooler you will have to use a set of lines from a newer truck. 61-66 trucks didn't use a radiator cooler. If you use any rubber hose, be sure it is for transmission fluid because the liner in regular fuel hose will not stand up to type F fluid.
1967-70 Ford Truck F100 F150 F250 2WD 5/16" Trans Cooler Lines 2pc OE – Inline Tube
Old Jun 7, 2023 | 08:05 AM
BobbyFord's Avatar
BobbyFord
Just buy a tube bender and make your own.
Old Jun 7, 2023 | 06:31 PM
tbm3fan's Avatar
tbm3fan
So looking at these the obvious question would be what trans they can hook up to. You have a non-original C6 in your 65 and I have the original C-O-M in my 65 and the add says 67-70. In my 65 the radiator had a cooler and rubber lines were used from trans to the radiator and I still do that today even though there is a separate oil cooler in front.
Old Jun 7, 2023 | 11:00 PM
Dodgeyaussie
Which is what I said I might do, the question was about the routing of the original lines.
Old Jun 8, 2023 | 04:13 AM
Crop Duster
Read through this thread. Cooler lines block to trans broken - Ford Truck Enthusiasts Forums (ford-trucks.com)
The original radiators in our trucks did not have a cooler in them. The difference in the dimensions where the cooler lines attach to the transmission whether it be a COM, C4 or C6 are minimal so the same lines will work on any of them. Providing whatever radiator, you have has 5/16 inverted flare fittings.
If you want to know how they were routed and attached, you will need to find a 68-72 truck to look at.
The cooler lines must be connected because the front line on the trans is from the converter relief valve and the rear line is lubrication for the output shaft bushings. That is the only forced lubrication those bushing get on any of the auto transmissions.
Old Jun 10, 2023 | 12:14 AM
Dodgeyaussie
Thank you for this
Old Jun 10, 2023 | 12:15 AM
Dodgeyaussie
Thank you!
Powerslide
Jan 30, 2023 02:53 PM
Gouldam2015
Feb 3, 2021 12:02 AM
smash fascism
Jan 11, 2019 07:07 PM
SoCalAngler
16
Apr 23, 2014 06:06 AM
mxracer3276
Feb 22, 2010 07:11 AM
