Need Help.
Old Jun 6, 2023 | 04:25 PM
runninvtec's Avatar
runninvtec
Trailering
Need Help.
Hey y'all. I got a 1989 F150 XLT Lariat with the 351 Windsor motor. It had a misfire. I replaced the plugs and wires on it and the misfire went away for about two days. It came back and a mechanic told me it was the dist cap and button rotor going bad. I replaced those. Now the truck starts, but it dies a few Minutes after running whether it idles or it's actually driving. I am adding a video of what it sounds like. I have also replaced the ignition coil and am getting ready to replace the ICM. Does anyone at all have an idea of what's going on?
File Type: mp4
Old Jun 7, 2023 | 08:11 AM
sswari's Avatar
sswari
If it was running even with a misfire, prior to you doing the plugs, wires, and distributor cap, and now it is not running now, make sure you have the wires in the correct order, you put all the vacuum lines back and that you did not break any.
Old Jun 7, 2023 | 12:21 PM
manicmechanic007's Avatar
manicmechanic007
You did not by chance move the distributor and the ignition timing is now off a bit?
broncobasher
Aug 24, 2021 06:08 AM
IowanStraight6
Nov 25, 2012 01:42 PM
kx100kicks
Feb 6, 2006 12:34 PM
tundrakat
Nov 23, 2000 08:44 PM
