51-226 water pump spin
Waterpump pulley width
I don't know if I was even spinning the water pump in the correct direction in my video. Maybe the video will help show if it is actually a worn out pump or not. I'm hoping it's still useable....makes it easier on the wallet.
The generator, crank and water pump pulley had a 3/4 flat H and was seated nicely all the way down. After some research, I found that ford did put that 3/4 belt and pulley in sometimes.
The pulley I ordered separate from the new alternator because they only came with v belt pulleys, supposedly it claimed to fit 5/8-3/4 belt. My old 3/4 belt fit perfectly on crank and h20 pump. I went to my local oreilly and was able to order a belt that seated on the new pulley and water pump pulley. I wont know if it works until I hook everything back up.
restoringmy46
01-26-2009 06:43 PM
ddbuggins
12-15-2004 12:28 PM
