Howdy all, I need some advice on an engine problem. I was towing my RV with my '87 f250, 460/c6 and as I was coasting downhill the engine started backfiring. Before I could get my foot back on the throttle to give it some air, there was a massive backfire and then the engine died, no restart. Got it back to the house and started troubleshooting this morning, it's getting fuel, getting spark and all cylinders are building ~140 psi. I suspect some of the lifters may have collapsed, when I pulled the valve covers I was able to push down on quite a few of them and they felt sort of spongey. Pushrods look good, I checked the cylinders with an inspection camera and they look ok. If anybody has experience with this sort of problem, I'd love to gather some insight before I start throwing parts at it. Thanks in advance for your help!
Definitely sounds like a timing problem. Possibly a sheared roll pin on the distributor shaft as Sandymane mentioned. Could also be a failing Ignition module, but those usually start working again when it cools down.
I pulled the dizzy, the roll pin sheared off clean as a whistle. Got the gear out and looked down into the opening but couldn't see the ends anywhere, hopefully they're back down in the sump. I had the imitial timing set at 15° btdc, havent touched the timing curve at all and it ran great right up until it didn't
10 degrees BTDC is the standard setting. Usually an advanced setting is no more that 12 degrees. When you set the base timing did you remove the spout?
I did, once I got it set and hooked the vacuum advance up it was showing ~30° btdc. I'll order a new dizzy and get it installed, in your opinion would it be worth replacing the lifters as initially suspected or no
This is what is supposed to do. When you pull the SPOUT the computer is removed from the timing program and 10 degree BASE TIMING is done manually by the user.. When you plug the SPOUT back in the computer is back in control of timing and adjust depending on preset parameters. I am not knowledgeable to know what to do about the lifters if anything.
The roll pin pieces are sitting in the bottom of the oil pan. Dont worry about them. You might be able to fish them out with a magnet at your next oil change. There is a mesh screen on your oil pick-up, so the pieces cant get into your oil pump.
I wouldnt bother replacing the lifters. Oil pressure keeps them pumped up. You'll hear your lifters tapping if they are bad.
A 1987 truck with a 7.5L engine has a carburetor from the factory. No fancy computer on these trucks.
rla2005 beat me to it, she's a carbureted monster. I'll just stick to the distributor for now and go from there if anything else is needed. I do know I'd be lost with this forum, I can't thank y'all enough for the help
Is there a good way to clear it if it is? I haven't noticed any pressure issues, I've got a standalone gauge and it shows 60-70 psi on startup and once it warms up it drops to 15-20 at idle and can get back up to around 40 when I'm getting into it. Not really sure if that's normal or not, this is my first bbf
That's the smoking gun, the pins sheared right out of it. What's the likelihood that the pieces fell back to the sump?
Most of the time the pin parts stay in the gear & shaft and dont get loose in the motor.
The pin goes thru the gear and shaft and out into the gear on the other side.
So the pin would be in 3 parts, each side of the gear & the shaft.
Now why did it shear is the real question?
Did a old valve seal make it by the pick up screen and jam the oil pump?
You may want to try and turn the oil pump to make sure it still turns.
When you use a socket on an extension use tape to hold the parts together so they dont fall down in to the motor.
Dave ----
