License plate light
Old Jun 3, 2023 | 10:40 AM
78Custom302's Avatar
78Custom302
License plate light
I'm replacing my license plate marker lights and the replacements I bought only have the hot wire--no ground. I suspect the ground (should) works because the fixtures touch the frame of the truck for ground. However, my truck is too rusted to pick up the ground from the frame. Any suggestions?
Old Jun 3, 2023 | 11:09 AM
dlburch's Avatar
dlburch
have you tried taking one of the bumper bolts out and grinding a bare spot on the frame and on the bumper bracket? If you do that and clean up the bolt/washer/nut it should provide ground from the frame to the bumper. If that doesn't work, worst case you would have to run a ground wire from the body to the license plate light housing.
Old Jun 3, 2023 | 11:16 AM
78Custom302
I'll try that. Thanks.
Old Jun 4, 2023 | 08:04 AM
NorEaster603's Avatar
NorEaster603
The lights i used from Bronco Graveyard use the bumper as a ground. I sanded an area down to bare metal and the light house screwed down and pressed into that metal. It’s working so far. If you’re paranoid you could solder a ground lead to the casing but that’s unnecessary.
FFunhundred
Mar 14, 2017 10:57 PM
5150 fear
Jan 5, 2015 09:21 AM
Arnold Kenyon
Jan 15, 2008 12:53 AM
themaker
Feb 25, 2004 08:39 AM
ROTCJS
Paint & Bodywork
Apr 16, 2003 11:14 PM
