Please help
Old Jun 11, 2023 | 07:30 PM
  #46
rla2005's Avatar
rla2005
Already answered your question concerning Code 13. You are failing the low speed portion of the test. It is not an indication the idle RPM is low.
Old Jun 12, 2023 | 05:30 AM
  #47
Bigredf1505.0's Avatar
Bigredf1505.0
Originally Posted by danr1
Back in post #34 Randy asked the result of unplug the IAC with the engine running, did not see where you post the effects of doing so.
If you have not done so yet, knowing what if any change that makes would be helpful.
Apologies if I missed it.
had no effect. Hadn't tried again since got new iac.
Old Jun 12, 2023 | 05:40 AM
  #48
Bigredf1505.0
am I doing the test wrong? When 8cyl comes up I do the steering wheel turn, then mash and release brake, then wait for code reader to say 10r then hit throttle. Am I supposed to wait to hit throttle or something? Is it a failure on my part or the engine/computer? If it were a sensor wouldn't it have another code or check engine light? That is what makes me think the lower intake gasket because high idle is like a vacuum leak. But I don't have anymore vacuum leaks and when I spray starting fluid around intake get nothing. Maybe the throttle body itself?? Or am I just expecting to much for the truck to idle at normal rpm in park. Do you think this would be a problem if I go ahead and start driving it?
Old Jun 12, 2023 | 05:54 AM
  #49
Bigredf1505.0
Code 13 KOER indicates the computer cannot control the idle RPM in the lower range during testing.
A small vacuum leak will cause no load idle RPM to be too high. Under load, in drive/reverse, the effect of the small leak is less noticeable.
How do I test for this? I repaired all visible vacuum leaks.
Old Jun 12, 2023 | 06:17 AM
  #50
rla2005's Avatar
rla2005
Code 13 has nothing to do with human interaction during the KOER tests. As I have stated before the computer is testing the idle RPM in an upper range and lower range. Code 13 is flagged during the lower RPM range because the computer cannot control the RPM via the IAC since the "base" idle RPM is too high.
Your issue with the high idle is most likely not caused by a sensor...more likely you have a vacuum leak. Less likely someone has jacked with the throttle stop screw since the RPM in Drive appears to be okay.
There is also a throttlebody gasket as well as IAC gasket. The throttlebody itself can be worn at the shaft or blades which introduces unmetered air, aka vacuum leak.
Another example for not using the spray method to find a vacuum leak on an EFI vehicle with dozens of feet of covered vacuum lines and external vacuum operated mechanisms that can and will introduce unmetered air.
That is also another possibility as stated above.
It is not an unrealistic expectation for the truck to have a normal Park/Neutral idle RPM as well as in Drive.
You could start driving the truck, but I would still work on identifying where the extra air is coming from soon.
Old Jun 12, 2023 | 06:18 AM
  #51
toolman60's Avatar
toolman60
Mechanics stethoscope to listen for leaks,propane torch on but not lighted to move along all possible places for vacuum leak and listen for increase in RPM, Carb cleaner spray same as propane, spray all possible areas for leak,EVAP smoke machine,King Edward Cigar blow the smoke into vacuum line. Or air compressor with regulator on it set at 2 psi and soapy water mixture. With the air compressor method you do not have to deal with running motor.
Old Jun 12, 2023 | 06:25 AM
  #52
rla2005's Avatar
rla2005
Process of elimination. Unplug and cap all of the vacuum lines at the vacuum tree on the upper intake manifold, as well as the one on the rear for the PCV valve, except the fuel pressure regulator and MAP sensor. Start the engine, then unplug the IAC. If the idle RPM returns to normal or the engine stalls the vacuum leak is external to the engine. If the idle RPM is still high, the vacuum leak is on the engine.
You can use a hand held vacuum pump/gauge to test each vacuum circuit. Some folks have built their own smoke machine to test for leaks. Just to verify, I would also check the the throttle stop screw to see if someone has jacked with it. Some folks think it is an idle adjustment screw. Look for signs of the blue loctite being compromised. As stated before messing with that screw also affect the idle RPM in Drive.
Now is the time to find the hidden ones.
Old Jun 12, 2023 | 06:26 AM
  #53
rla2005's Avatar
rla2005
had no effect.
Another sign you have a vacuum leak.
[/QUOTE]Hadn't tried again since got new iac.[/QUOTE]
You should test again.
Old Jun 12, 2023 | 07:50 PM
  #54
Bigredf1505.0
Rla2005, thank you so much. I need the truck as a only running vehicle right now and will be running it. Will update when I work out this little grimlin causing the high idle. I think you gave me all I need to work it out, and will be, as soon as I get another vehicle going for work. keep a look out for the update.
1989bricknose
13
Mar 18, 2018 11:56 AM
Mattladoux
May 1, 2017 01:43 AM
jdub122
1997 - 2003 F150
15
Feb 4, 2014 09:58 PM
FixrUpr8
15
Jun 16, 2005 09:35 PM
great300
Aug 19, 2004 06:05 AM
