New Member
Old May 31, 2023 | 07:55 PM
Copperspur7's Avatar
Copperspur7
3rd Gear
New Member
Good evening to all. Proud owner of an Early 99 F-250 PSD. I’ve owned this vehicle since 2000 and am the 2nd owner. Purchased it with 60,000 mikes already on it. The previous owner drove the heck out of it that first year!
I pulled the motor at 367,000 and rebuilt it, increased the horsepower by roughly 200 hp. Bored the block .030 over, all new .030 over pistons, new stage 2 Colt cam, new hybrid injectors 180cc/80% nozzle. Rebuilt the heads with Comp Cam heavy springs, all new intake and exhaust valves, .060 clearance on the springs. Smith Brothers heavy pushrods. Hydra 6 position tuner.
South Bend 450 HP clutch
I still have a lot to do, ran out of money and had to get this thing back on the road. It now has 33,000 on the new rebuild and had power and then some. I am still replacing 24 year old components. I previously started to get a surge of about 1,000 rpm’s at idle and rough idle, slow & hard start. I replaced the fuel pump, under valve cover harnesses, main harness, ICP, IPR, CPS, EOT, EOP, IAT. Changed the oil, air filter, fuel filter.
Unfortunately, although it is running better, my problem persists.
I downloaded the Forscan program and noticed some strange numbers out of my ICP. It would only get up to about 1,300 psi (and I’m rounding up!) was really only 1,200 and some change. The IPR was at 22%. I’m now leaning to replacing the HPOP with the Adrenaline.
Looking forward to helping out when I can and getting help in return.
I need to find out about our Florida Chapter.
Thanks to all.
Old May 31, 2023 | 11:12 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Welcome to FTE, make sure to join your FTE state chapter. The maim forum list has each state down towards the bottom. Scroll & locate and get singed up. https://www.ford-trucks.com/forums/forum13/
Old Jun 2, 2023 | 12:19 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Be sure to check out the "1999 - 2003 7.3L Power Stroke Diesel" forum!
For the Florida Chapter, follow this link: https://www.ford-trucks.com/forums/forum116/
Welcome aboard!
ElizabethRanee
New Member Introductions
Mar 7, 2016 01:19 PM
Ryan50hrl
May 31, 2010 04:06 PM
vroc55
Dec 20, 2007 03:57 PM
