1966 - 1977 Early Broncos
harmonic balancer/ crankshaft spacer
Old 11-18-2003, 11:08 AM
ROKRAWL's Avatar
ROKRAWL
ROKRAWL is offline
I'm putting my 351 w back in my bronco and am having a hard time remembering if there is a crankshaft spacer that needs to be installed before the harmonic balancer. I sure have learned my lesson to label all the bolts and parts better for next time. If anyone knows whether or not the spacer is needed or where I may be able to find one would be appreciated. thanks
Old 11-18-2003, 11:38 AM
spartamouse1's Avatar
spartamouse1
spartamouse1 is offline
no spacer behind the balancer. i used my old front cover, timing pointer and balancer off of my 302 and put it all right on the 351w.
Old 11-18-2003, 11:46 AM
spartamouse1
i just went through the 302 - 351 swap last month. anything you need to know i just went through it. little pain getting things adapted to work but let me tell you it was worth it. love the power.
Old 05-27-2013, 07:10 PM
Kevin302's Avatar
Kevin302
Kevin302 is offline
I'm putting in a 302 and bought a pioneer balancer and installed it and Im out a belt thickness which is
.500 spacer, and found out that they only make a .350, .750 and .950 spacers so what are my options
gary's1950F1
11-21-2016 11:11 PM
1982fordf100
08-02-2006 09:08 PM
Jeff Fisher
04-26-2006 07:51 AM
ExcellentRed
08-01-2004 04:52 AM
bluesky636
02-01-2004 05:26 PM
Quick Reply: harmonic balancer/ crankshaft spacer
