2023 Super Duty shift issue.
Hi, new member and new to Ford.
Picked up our new 23' long awaited SD 350 SRW CCLB 7.3 last Monday, behaved beautifully climbing and when starting down the backside of the mountain towing a 6,000 lb camper started to downshift nicely, then it kept going, at 50 MPH it was in third and trying for second, nothing seemed to make it shift up until I put it in manual and forced it to. It did this one more time, then seemed to behave after that all weekend and on the way home. The dealer said it is still learning. Anyone have any insight on this behavior?
TIA
Seth
TIA
Seth
The following users liked this post:
Received 6,811 Likes
on
Tow Haul going downhill, especially towing, is ridiculous. I have repeatedly experienced the same with my '22. Sadly, that is just how it is programmed. I can drive miles applying throttle after a down hill and the trans will not upshift on its own for WAY longer that it should. Dropping to manual mode and using the button the bring the gears up is the only "solution" I have found. Not using T/H going downhill is my next line of defense, normal does better, manual best.
Try using cruise. I never had any desire to use it while towing but after watching a video of a towing battle on utube he used cruise to let the trucks do their things. So last weekend we went to devils lake in Wisconsin and it’s pretty hilly around there and I tried it out. What a difference it made didn’t have to even touch the brakes the truck did all the work. Only thing I didn’t like was it drops two gears sometimes going up hills when it probably only need to drop one. I was impressed at how well it did.
These new transmissions are always "learning" (not learning, but adjusting to conditions and driver inputs). There is no "learn for 1000 miles then keep those settings forever".
The following 2 users liked this post by Under-Pressure:
