Radiator capacity
Old May 26, 2023 | 04:16 PM
carl2591's Avatar
carl2591
Radiator capacity
Trying to figure out just how much fluid is in the radiator by itself I had a hose clamp let go at the campground we're at up up here in Banff and I got it back on apparently it slipped off from replacing the radiator a while back and I didn't go back into check to retighten it and all the liquid drained out of the radiator I've got 3 gallons of new coolant and I added water to it I just need to know what the capacity of the radiator.
I plan to drain the radiator completely and then pour in the proper amount of coolant and then add water to it so that's why I need to know thanks
Old May 27, 2023 | 02:07 AM
udsuth78's Avatar
udsuth78
Roughly 5 gallon is what I got last time I drained mine from the petcock.
Old May 27, 2023 | 02:17 PM
carl2591's Avatar
carl2591
Cool thanks. Did not get all the way drained. Added 2 gallons of new ELC and have added 2Gal of old red and a 1.2 gallon. Getting close to steady in the tank.
Old May 27, 2023 | 02:38 PM
udsuth78's Avatar
udsuth78
Does the elc and the red/pink play nice w/ each other? I know the old school green will turn to jelly if mixed but not sure on the other.
Old May 28, 2023 | 02:59 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Aside from the compatibility issue, I would not fret too much about striking a 50/50 balance of coolant and water. Err on the side of water while on the road.
Do the whole job right later when you have the time.
eenyok
Feb 2, 2023 05:25 PM
mpmccarthy
Aug 11, 2011 05:53 AM
idahodisco
Apr 18, 2010 10:41 PM
urg
Oct 22, 2007 04:11 AM
