Headlight flashing can sometimes occur due to a bad DRL module (daytime running light module). It's the black box with fins on it attached to the wall beside your battery. 10 minute job to replace... but first diagnose the problem.
I'm in Canada so I'm not sure about US models. I think it became manditory in '89 or so for all vehicles to have DRL's. When my drl module acted up the lights would intermittently go on and off and when I turned off the van the lights stayed on sometimes - always the highbeams b/c the drl's are actually the highbeams running with a reduced voltage so they are dimmer. That's what the DRL module does. It does not, however, seem to explain signal light issues. JR
Yea, I don't see the connection either. In my book they have a different power source/fuse.
I've got a 94 and 96 Aerostar now and had a 91 before. None of them (all US) had the DRL. My 94 is an Eddy B. package and the lights will come on automaticaly and go off after a delay. That's a nice feature.
I don't have a diagram that includes the DRL. I agree with aletheuo that it's probabily related to the DRL module.
With regards to the turn signals, I suggest you check your fuses first. Also check the position of the hazard switch. I have a problem on my 96. With the hazard switch off the turn signals work fine. With the hazard switch on I get neither the hazard nor the turn signal. Left or Right will not work if the hazard is on. I get nothing. We could have the same problem.
I stumbled accross this site after looking for a reason for the same problem you are having, flickering headlights. I read the post about drl so I am trying today unplugging the little black box. The lights seem to work normal. So what the hell leave it off until I get a part from the wrecker. The problem is solved right. I hope so. I have the same as you a 95 areostar. As for the signals. Could it be the flasher??? Because if you have to take the steering wheel off. I have had no luck with thaat. Cheep white metal junk the threads strip everytime I put on a wheel puller. I end up getting a whole column out of the wrecker. If the signals slowed down over a period of time and know dont work at all then I would say for sure its the flasher. Just some ideas.
I did do a high low flip of the switch a couple of times in the driveway. It did seem to work. I will do some testing tonight and see what happens. of course, this was after I disconnected the DRL box. So I will find out tonight and let everyone know tommorrow.
well after unplugging it and waitting all day to get dark went for a test drive and the lights worked fine for a while but then started to flicker. got home and screwed around with the headlight switch and have come to the conclusion I will change it to see what happens
