carb base measurements
Old May 26, 2023 | 10:35 AM
artscott61's Avatar
artscott61
Veteran: Navy
I just purchased a 2 x 2 offenhauser manifold for a 51 flathead. The carbs i have will not fit on the manifold. The offenhauser measures 3" center bolt to center. Does anyone know what carb I might have to use ? The carbs I have now are the holley ford.
Old May 26, 2023 | 01:52 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I'm not clear what you mean by "center bolt to center"? 3 bolts? Does the Offy manifold have a p/n cast into it? Any chance it is for an earlier 59-series flathead?
Old May 26, 2023 | 02:14 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
For a 51 flathead, it should be an Offenhauser 1075/1076 that accepts the standard 3 stud carburators {Holley 94 variants, Stromberg 97, Holley 2100 etc)
Old May 26, 2023 | 04:26 PM
artscott61's Avatar
artscott61
Veteran: Navy
It is a 1075 looks to be cast in 3/12/97 which doesn't mean much. Ross the two rear bolt holes is what I am talking about. What I meant is the center of the hole to the center of the other rear hole.
Old May 26, 2023 | 04:41 PM
bmoran4's Avatar
bmoran4
I think the actual center to center is 3 3/32"
Old May 26, 2023 | 05:06 PM
artscott61's Avatar
artscott61
Veteran: Navy
Well now I have made an *** of myself. I put in the new studs that I bought and set the carb on and low and behold it fit. I want to thank all of you for responding. So much for just eye balling things. Thanks again guys and hope you have a good Memorial Day remembering our Vets that have passed before us. I have been around flatheads most of my life but not to the extent that I am going to get into them now.
Old May 27, 2023 | 10:55 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
It happens to the best of us Art, Just not often.
Old May 31, 2023 | 07:31 AM
ajsunnyB's Avatar
ajsunnyB
I just got a eddlebrock carb for my 312 Y Block small wriser with the unit. It bolted right on. Replaced my Holley Had issues. AJ
perry xxx
Jan 2, 2022 11:29 AM
firemenjay
1966 - 1977 Early Broncos
13
Jul 3, 2010 09:33 AM
F100racer08
Jun 8, 2008 03:37 PM
fordeverpower
Aug 2, 2003 10:13 PM
lastcast
Sep 7, 2002 09:33 PM
