Trailer brakes when set to zero
Old May 25, 2023 | 09:36 PM
cat-alac's Avatar
cat-alac
Both the 2022s I’ve had will activate the trailer brakes even though set at zero, I have lighter flatdecks that really needs no help when empty so I select 0 and the trailer brakes still activate, I thought was just an issue on my previous 2022 F350 srw cc, but the second does the same???
With the 20-21 i had normally I’d set to 1.0 or so empty but that same setting on the 2022s really activates things. I have 3 flat decks all the same deal so think is definitely the truck.
Old May 25, 2023 | 10:15 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
A zero setting makes the trailer brakes grab enough to be an issue???
Maybe the trailer brakes are set too tight.
How do you have the trailer brakes set to in the dash cluster?
Old May 26, 2023 | 11:36 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Interesting. I use 3.0 on my empty 18’ trailer and I can barely tell they are working.
Old May 26, 2023 | 11:57 AM
Alloy's Avatar
Alloy
With both my F350 and F450 when bringing a loaded trailer to a stop the controller seem to cut the trailer brakes to 0 because I have to drive the brake pedal to the floor..
dennis11
All Things Towing
Mar 30, 2022 01:03 AM
kopy kat
All Things Towing
Sep 29, 2021 12:04 PM
th3jared
2015 - 2020 F150
Jun 23, 2019 09:11 PM
docgj
2009 - 2014 F150
May 10, 2011 01:55 PM
tndiesel
Aug 6, 2007 03:01 PM
