Gear indicator value
Old May 25, 2023 | 03:28 PM
Anonymous12's Avatar
Anonymous12
I asked someone to go get a column and the gear indicator cable for me, and they got the whole gear indicator. This one’s for a E4OD I think because I saw in the photos of the truck it came off of an electronic overdrive switch. Mines an AOD. How much is it worth so I can give them their money back and whatever profit is made? I know it’s gonna be more than what this pick your part charges. I can’t make out in the photo if it says P R N D 2 1 or P R N D D 1. I see refurbished for $150. Thanks.
Old May 25, 2023 | 04:11 PM
Anonymous12
Here’s a better photo of it, id take the cable off of it.
Old May 25, 2023 | 04:14 PM
TexasGuy001's Avatar
TexasGuy001
Those are typically sold as a indicator and cable together as an assembly.
Old May 25, 2023 | 04:21 PM
Anonymous12
I know the cables worth like $50 on eBay for some reason. It’s like $40 new on Amazon too it’s crazy for plastic and some copper wire. So I know I’d get less but I need the cable mine broke.
Is there a way to swap the black cover from my truck to the other indicator?
Old May 26, 2023 | 08:40 AM
manicmechanic007's Avatar
manicmechanic007
They are worth what you can get out of them
I have a brand new one in the box, waiting for just the right vehicle
If you go to the junkyards around here you will find all the cable adjuster / holders missing
They are all in my toolbox
Old May 26, 2023 | 02:50 PM
My4Fordtrucks's Avatar
My4Fordtrucks
It says E4OD on the bottom. I’d say the cable is more valuable since that is what gets broken when people don’t know to be very careful when disassembling the dash.
Old May 26, 2023 | 04:33 PM
toolman60's Avatar
toolman60
Looking if yours is exact same as the E4OD you may be able to trim the 5 little tabs across top and bottom and swap them. Just got to figure how much your time and sanity worth.
manicmechanic you been in VA picknpull too. That's a hot item here also to get pulled.
Anonymous12
Mar 17, 2023 11:18 AM
Iceman_AKA_Ford guy
Aug 23, 2010 01:44 PM
RRE101
May 14, 2010 10:54 PM
